Question about Kenmore Dryers
Clothes dryer velocity has slowed down to point that clothes do not dry. Thank you very much. Paul J.
  • Kenmore Master
  • 3,740 Answers
Hi Paul and welcome to FixYa. I am Kelly. When you say velocity I am assuming we are talking about airflow and not the tumble speed. There are 2 things that cause poor air flow.
1. Lots of lint build up either inside the dryer or in the output vent ducting expecially at the outside thru the wall vent flapper.
2. The blower wheel on the drive motor has a damaged center hub and is spinning on the motor shaft vs driving at full speed.
Pull out the lint filter use a flashlight and look in the very bottom area of the lint filter air passage. This area is notorious for lint accumulation. If you note lint use a vacuum crevice tool and a wire coat hanger folded into a U shape to reach deep into the passages so that you can use the crevice tool to remove the lint.
The lint filter itself can cause restricted airflow. If you use dryer sheets (Fabric softener) these over time accumulate a mirco particulate on them that when you wipe off the lint it appears clean but the air passages are clogged with the dryer sheet material. Wash the lint filter with vinegar and water using a brush, then soap and water.
Next go outside and check the thru the wall exhaust of the dryer vent. Reach up inside the flapper and check both sides of the flapper for lint build up. Clean as needed.
Disconnect the vent ducting at the back of the dryer. Start the dryer. The airflow commig out the back should gently push a relaxed hand away from the exhaust hole. If the air flow is weak use a flash light and look deep into the vent ducting inside the dryer checking for lint build up. Clean thoroughly.
If after doing all of the above you still have weak airflow then the blower wheel area is suspect in the form of either a damaged blower wheel or lint build up at the blower housing exit.
Give it a good cleaning and see what happens. If you sitll have air flow problems there is more I can do to help you with pictures and how to dis-assemble the dryer. Just repsond here and I will gladly help you.
Thanks for choosing FixYa.
Kelly
Posted on Aug 26, 2010
  • jcolombero
    jcolombero Jul 26, 2012
    Good answer, makes sense, as I have a similar problem. Following the above suggestions solved my problemThanks
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
The dryer does not pass 6 min mark and does not shut off. How would I test a humidity sensor? Thank you for help.
A dryer moisture sensor can stop working without notice, until you notice your clothes being over dried or still wet at the end of the cycle. It is a good practice to test the dryer moisture sensor periodically. There are two types of moisture-detecting sensors for dryers. Once you understand how they work you will see how to test each one.
1. Sensor BarThese sensors contain digits that protrude outwardly. They work on an electrical current and the moisture from the clothing.
The first step to test is to place completely dry clothes in the dryer and turn on the dryer; it should run for a few moments and then shut down right away.
Secondly, place damp clothes into the dryer, turn on the dryer and watch the timer. As the clothes begin to dry the timer will move and shut off.
2. ThermostatThe timer is regulated by the thermostat. The thermostat rests in a closed position. To test this type of moisture sensor, place damp clothes in the dryer. Watch the timer; as the clothes begin to dry, the thermostat should open and the timer will move forward ,eventually shutting off.
Sep 08, 2013 | Dryers
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
The auto dry sensor cycle shuts down before clothes are totally dry -paul
Hello Paul,
The problem with your dryer very likely is that the sensor bar is dirty and needs to be cleaned...especially if your using fabric softner sheets they leave a coating on the sensor bar and it cant properly read that the clothes arent yet dry.
Its very easy to clean the sensor bar,just need to use some rubbing alcohol and the green scrubby side of a kitchen sponge and clean the sensor bar,then rinse with plain water.
GENE
Sep 16, 2011 | Dryers
Dryer has heat but not hot takes forever to dry clothes
One of the most common problems with slow
drying involves the Vent
The best way to check this is to go outside
and check the velocity of the air at the vent
Clean the vent and the filter.
If you have no air outside then you may haven a blower wheel problem
(slipping on the motor axle.)
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Nov 20, 2010 | Dryers
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
My Maytag electric dryer runs the cycle, but the clothes are not all dry. Trying to avoid expensive repair. Is there something I can do myself?
First place to start is the dryer vent. Is it clogged where it leaves the machine or even furhter down. A clogged vent will dramatically reduce the efficiency of your dryer to the point where it may not dry clothes at all.
May 12, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
