Low ink warning light does not go out after replacing cartridge on my Epson R800
I have the same problem. My printer won't let me print anything- just as a E message.
Posted on May 19, 2008
The feed indicator light and ink light flash alternately (back and forth). the R800 won't print, allow cartridge tray to move, or feed paper.
Lights flashing alternately means that your printer's waste ink pad is saturated. It needs to be replaced and reset the counter. To reset the waste ink pad counter you will need a resetting program. You may download it by going to this link:
http://www.divshare.com/download/1140953-256
Aug 31, 2010 | Epson Stylus Photo R800 InkJet Printer
Red Light for (ink) comes on.(Epson Photo R800)
Epson has a problem that if it stays for one month or more the ink dries and it wont print.
usually what i do is taking out the head and put it in some alcohol. for a day or two. the i blow dry it or leave it dry for two or three days.
take a straw and blow into the holes real hard.till it works . try it. it is not easy
unaasp192
Apr 12, 2010 | Epson Stylus Photo® R800 InkJet Printer
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
Epson R800 The power light is solid green and the ink button is solid red. I cannot print anything because one or more of my cartridges are empty, but it won't allow me to use the Status Monitor to check...
Open your printer cover and press the ink button. The cartridge under the out of ink symbol is the empty one. The following URL has the details: http://files.support.epson.com/pdf/r800__/r800__00u1.pdf#page=80
If you press the ink button again and another cartridge lines up with the out of ink symbol, record that. Repeat until the cartridge moves to the replace cartridge position. Buy all the ink you need before you attempt to replace any of the cartridges.
I hope this helps.
Nov 15, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus photo 2100
Highly possible that the "compatable" cartridges are not really compatable or that Epson has updated software or firmware to keep them from working. Try replacing with Epson cartridges or see if the non-OEM brand seller has a resetting device so the printer sees those cartridges as full.
Dec 06, 2007 | Epson Stylus Photo 2100 InkJet Printer
Ink warning light
often tho they seem the same the alingment of the nozzles dont match, so check alingment most printers offer you a programme that will do this for you...
Aug 18, 2007 | Epson Stylus Photo R800 InkJet Printer
265 people viewed this question
jasbo
jasbo
