Requesting a diagram to show the correct way to install new agitatoe Dogs
    President:
  • 1,937 Answers
Please see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=acf429525aa328bfeb3756e7e3bdbcda
Posted on Aug 26, 2010
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Material does not feed therefore stitches are tiny. i have checked threading appears to be correct. Bobbin also correctly threaded. Feed dogs are up. Anything else I should look at. Many thanks
check the stitch length dial setting to see what it set on
the feed dogs job is to move the fabric so the needle can sew it
even if the feed dogs are in the up position the feed dogs may not
be working like they should and they may need to be checked.
Feb 04, 2013 | New Home Sewing Machines
Agitor does not agitate correctly. Possible dog or tog went out. Looking into ordering it.
If the lower part of the agitator turns but the upper part does not it will defiently be the dogs. The part number just for the dogs are 80400 the part can be purchased at your local appliance store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
this video will show ya how to replace the dogs
Gene
Aug 24, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Where do I get new feed dogs for the heirloom 6005? The current one does not pick up the fabric right, and I have to push it in with a seam ripper.
Are you sure the feed dogs are faulty, its more likely that they are full of fluff or need resetting if they are moving too low. Is your needle plate correctly installed too, if it is sitting up a bit high it will mean the feed dogs arent coming through the holes at the correct height.
I did buy a machine like this recently, owner said it did'nt sew. The needle plate was fitted upside down, 30 second fix!
If you don't have a repairer you know of in your area, then start with the Elna website www.elna.com, go to your country, then "Dealers" and locate your local Elna dealer.
Jul 10, 2011 | Elna Heirloom Edition 6005
The top agitator just keeps spinning.
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 05, 2011 | Washing Machines
Directios for changing agitator dogs
take the cam out take the yellow bushing off, put new dogs in, put yellow bushing back on, put agitator back into washer, put cam back in with dogs inside it, facing down, put bolt back in and cap. new dogs usuaully come with instructions.
Feb 10, 2009 | Whirlpool Washing Machines
Clucth Dog replacements in Agitato
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2009 | Washing Machines
A diagram of how to install a heater fan in a 1992 pickup
well its an easy replacment unhook the power and ground wires on the motor remove the bolts and remove the motor install the new one
Jan 11, 2009 | 1991 Chevrolet K1500
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
