Touch pad is too sensitive, in that when I touch it is like a left click on mouse.how do I reduce sensitivity
  • 320 Answers
Hi to reduce sensitivity go to start, control panel where you got settings for touchpad click on it. It's gonna open new window where you can customise settings if you need more help let me know
Posted on Aug 26, 2010
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
MY MOUSE KEEPS LEAVING THE SCREEN, AND GONE FOR 10 SECS..ITS A DELL LATTITUDE 600 NOTEBOOK-FIREFOX, XP
5
Feb 08, 2011 | Dell Lattitude D600 Notebook
I am using T400 with XP Pro. while typing Touch pad is so sensitive that it jumps the cursor from writing one line to other. End up that you need to type all the items again and again. is there any way...
Try this first
To do this, open Mouse Properties within the Control Panel, where on the Ultra Nav-Tab you find a button for touchpad settings. Click on this button and another window will open which has a tab for adjusting the sensitivity of the touchpad. Moving the slider to the left (towards "higher" ) greatly improved my experience with the touchpad.
For me, setting it to the second highest "line" (i.e. second line from the left) works best, but you may be able to set it even higher as I have not yet encountered any negative effects when doing so.
I would be glad if some of you could try to verify my findings, I am very much looking forward to your experiences.
Step 2
Click on the link below and follow the instructions
Touchpad Sensitivity
Also try this step below if above steps does not solve
  • Right-click on 'My Computer' and then select 'Properties' in the context menu. This opens 'System Properties' dialog box.
  • Click on the 'Hardware' tab and then on the 'Device Manager'. Here you will ?nd an entry titled 'Mice and other pointing devices' in the 'Device Manager' window. When you double-click on this entry, it shows the touchpad as a PS/2 Compatible mouse.
  • Right-click on this entry to go to the properties of the touchpad, select 'Advanced Settings', and then click on 'Sample Rate'. You can reduce the degree of sensitivity here.
  • Follow this tip and you can solve the 'jumping cursor' problem easily.
Thank you for contacting FixYa
Nov 27, 2010 | IBM Lenovo ThinkPad T400 7417 Notebook
The touchpad is so sensitive I can't control it
You've got it, your touching the touch pad, annoying isn't it.
You can try a couple of things,
1) Go to Start - Control panel - Mouse/Touch panel - and see if you can reduce the sensitivity or,
2) Disable your touch pad (Same route) and use an ordinary mouse instead. That's what the wife does.
Jul 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do you reduce the touch pad sensitivity in an Acer One Aspire Notebook ZG5? Thank you very much
In order to reduce the Touchpad sensitivity you may follow the following troubleshooting steps:
1. Goto Start--->Control Panel--->Mouse and then change the mouse sensitivity accordingly. Some laptops (like HP) comes with a Synaptics program which you may find in the control panel.
2. Double click the Synaptics and in the user interface, select the Touchpad sensitivity as per your needs.
Thanks & Regards, techbuddy247
May 26, 2010 | Acer Computers & Internet
My touch pad is SUPER sensitive, when I type, my cursor ends up all over the place. I read up on hitting the f7 key, but I am totally computer illiterate. When you guys say hit the function key, do you...
From Dell:
Customizing the Touch PadYou can use the Mouse Properties window to disable the touch pad or adjust the touch pad settings.
  1. Click Start keyboar4.jpg , and then click Control Panel.
  2. Click Hardware and Sound.
  3. Click Keyboard.
  4. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad.
    • Click the Touch Pad tab to adjust touch pad settings.
  5. Click OK to save the settings and close the window.
Oct 06, 2009 | Dell Inspiron 1526 Laptop
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Acer 5620 touchpad
Function F7 to disable the touch pad and the same buttons to enable it. The function key is the button with Fn. on it.
Good luck and don't forget to rate my answer.
Jan 11, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Sensitive touch pad
Hi, click on start and control panel. go to mouse properties. Try to look for a tab that says either touch or touchpad. you can change the sensitivity settings there. however if this doesnt work, this could only mean that this is a physical problem with the toucpad. try to apply pressure on the outer side of the touchpad. if it moves, you're gonna need a replacement palmrest.
Oct 02, 2007 | Dell F3534 Touchpad
Computers & Internet Logo
176 people viewed this question
David Payne
David Payne
