Question about Refrigerators
Gibson commercial freezer frost free - Refrigerators
    Genius:
  • 1,478 Answers
A mechanical defrost timer controls the defrost cycle of the freezer. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. In newer models the timer advances only while the compressor or defrost cycle is running - an improvement for efficiency. As the timer continues to advance, power to the heating element is cut and power is restored to the cooling system. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way.
Take care.
Posted on Aug 26, 2010
I lost the key for door of my kenmore frost free commercial freezer where can i purchase the key?
Hi, here is the replacement key for your model, you can purchase it for $ 2.65:
KEY (Freezer Door Key)
To buy the part call toll-free at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time, Monday to Friday and Saturday from 8:00 AM to 6:00 PM Eastern time. Mention part PS426673 (Part Select Number).
Good Luck
Aug 22, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
I have ice building up under the basket. It is
I would check your door seals to make sure they are doing there job. If warm moist air gets into an area of cold this will happen. You may need to get new seals for your freezer door.
Oct 07, 2009 | Whirlpool 19.6 cu. ft. Commercial Freezer...
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Sep 14, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Frost free freezer smells like fish
IF THERE WAS A LAYER OF ICE ON THE BOTTOM OF THE FREEZER, THE DRAIN IS PROBABLY PLUGGED UP. IT WILL NEED TO BE CLEARED BEFORE PUTTING BACK INTO SERVICE OR IT WILL JUST DRAIN INTO THE FLOOR OF THE FREEZER AGAIN. AS FAR AS THE ODOR, TRY PUTTING CHARCOAL IN IT TO ABSORB THE ODORS. IT WILL HAVE TO BE LEFT IN THERE FOR QUITE A WHILE. WHEN THE FREEZER IS CHILLED, IT WILL LESSEN THE SEVERITY OF THE ODOR. IF THAT IS UNACCEPTABLE, THERE ARE COMMERCIAL ODOR NEUTALIZERS ON THE MARKET YOU CAN USE.
Mar 30, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Evaporator freezes up
No model # .. Im assumeing its frost free.. so that means a defost problem.. heaters, defrost themostate or timmer.
Aug 30, 2007 | Coldtech 21 cu. ft. / 595 liter Commercial...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
