Question about Panasonic KX-T7633 Corded Phone
How to use the intercome? and Paging system? - Panasonic KX-T7633 Corded Phone
  • Panasonic Master
  • 2,460 Answers
How so? The TDA/TDE systems have page groups and external page is assigned to one of those groups at installation.
At the very minimum, you should be able to dial *3301-33xx on the intercom and page the different phones and external page assigned to that group. IIRC by default, system phones are usually in group 01. In passing, I think *43 from any phone will answer said page and cut off the speakers.
As far as the intercom, each phone is numbered and the extensions usually start a 101. You dial and it either rings or tones (that can be programmed) and you can use the intercom.
Somewhere, there is a user's guide (UG) for the phones. It's particular to the phone system, but the TDA book is universal for all systems. If you need it, comment back with your system model and I'll drop a link to you.
Carl
Posted on Aug 27, 2010
Page port testing
I am not sure what #617 is but the loudspeaker paging access code on the Partner ACS is intercom 70. If no audio is heard from the paging port on a test set when this is dialed then the paging port is defective. There is no programming necessary to enable or disable the loudspeaker paging access code.
Jan 10, 2013 | Avaya Partner ACS 308EC (108463001)...
How do I turn the intercom off at an individual handset?
Do you mean intercom or paging? You can turn off paging by setting the Paging Deny code. From the intercom dial *7211 with 10 being the allow code. As far as the intercom, onlly Do Not Disturb (*7121) will fix that (as always change the 1 to 0 to allow). The DND light will light solid and when you press the button, the display will give you information as to what is set.
Carl
Jun 16, 2011 | Panasonic KX-T7630 Corded Phone
I want to kow how to use / program the paging function on the KX-T7633.
What happens when you dial *3301 or *3332 on the intercom? At installation, phones are assigned paging groups, and they usually fall into group 1 by default. There are codes that can lock phones out of paging (each user can do it himself) and 32 is all page groups. Anybody can dial *43 on the intercom to join a paged call.
Carl
Jun 13, 2011 | Panasonic KX-T7633 Corded Phone
I would like to use an intercom system on my phone. Is this possible with a 4412d? If so how do I do this?
when you say intercom system, do you mean overhead paging?
YES, it can page a phones speaker or an external paging system.
Also, a 4412 can be used on a few different systems, you will need to know more info, and I would call a technician, as this might be some pretty tricky programming, especially if it is an IP Office.
Jan 12, 2011 | Avaya AT&T Merlin Handsfree Answer Back on...
I need to know how to page another extension. Our Avaya phones do not have the intercom button. I thought there should be a function code to program a button for Intercom, but I'm not finding it. I need to...
There are 2 buttons right below Line 1 and Line 2. Those are both intercoms.
When paging a phone, you just insert a * (star) before the extension number.
SO, Intercom*11, will page extension 11
To program on a button, feature 00, press the button you want to program, then press the left intercom and *xx (where xx is the extension number)
As far as paging all the phones, you will need to have them in a calling group (1-4), hten you can page the group to page them all.
Jan 19, 2010 | Avaya 700340193 Corded Phone
Intercom paging not working on avaya partner phone
Are you paging the overhead speakers, or paging the speakers on the phones?
Jan 27, 2009 | Avaya 700340193 Corded Phone
158d system
The paging connects to one of the line ports on the system. Its needs to be specified in system programming which line you will be using. When you login to System programmiing (feature-0-0-left intercom--left intercom) you can go to Loudspeaker Paging Line #617, then select an unused (available) line. (feature-0-0) to save. Then go to the system and the port of the line you selected is where you will connect the signal leads to the paging horn. Then use Intercom *70 to page or program a paging button
Aug 25, 2008 | Lucent PARTNER18 Corded Phone
Lost manual and can not page the warehouse .....
Well, before you program the button, you need to see what you have to program. At a phone whos paging button works, press FEATURE 00, and touch their paging button.
If it says loudspeaker page....GOOD. If not, repost with what it says.
FOR LOUDSPEAKER PAGING: From your phone
Feature 00
Touch the paging button, press LEFT intercom and 70
Feature 00 to get out of programming.
Done.
Mar 24, 2008 | Lucent PARTNER18 Corded Phone
Partner 18D intercom not working
If you mean intercom, as in Speaker/overhead paging, then the buttons need to be reprogrammed to access the intercom. If you mean calling from one avaya phone to another, then the system is more then likely fried. from your system press the intercom button, 61. that should give you the paging access that I think you are looking for.
May 21, 2007 | Avaya Corded Phone avaparp18d
Panasonic KX-T7633 Corded Phone Logo
148 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
