Question about Philips Televison & Video
Disconnected my dtr210 now it stuck on one channel and remote doesnt opperate it, bats ok?
    Sergeant:
  • 252 Answers
Thats easy. All you have to is make sure your antenna is hooked up. Then go to your menu and do and autoinstall. You see when you disconnect Yor Phillips Dtr210 it automatically looses its memory of your chanels just like if you unplug your TV. Do this and you shouldnt have anymore problems unless you unplug it again.
Posted on Aug 26, 2010
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
Cant seem to get my remote to respond to the recorder
Panasonic remotes have two channels. Press OK and simultaneously 1 and hold for more than five seconds. Then try to power up using the remote. If that doesnt work press OK and 2 and hold. One of those will control the machine. Make sure you have good batteries in the right way.
Oct 19, 2013 | Panasonic Eur7624kb0 Remote Control...
Fan not working/cause? will not opperate car over heats.
did you test your fan? ive had this problem before. i disconnected the fan and took a jumper wire off the battery and put them on the connector. If the fan doesnt work id replace the fan. But before this i would do the simple thing and check the fuses. If this doesnt work follow the wire back and look for a bad wire.
Apr 23, 2010 | 2000 Chevrolet Malibu
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
No charge to bat but runs ok for 2 weeks so far
Sounds like dead battery cell Have bat checked.It's not a good idea to disconnect the battery on a modern computer controled vehicle while the car is running.
Sep 16, 2009 | 2000 Cadillac DeVille
How do we fix the remote?
Have you tried to insert the remote codes on there again? Some remotes might reset if you take out the batteries but higher end ones do not since they have an internal back up system.
Try the codes and if that doesnt work then let us know.
Otherwise make sure the press the correct "source" you intend to opperate with it. such as the DVD player on component, or DVR on HDMI, etc... Some times if the wrong source is pushed it wont work. But normally pressing it will fix the problem.
Keep us posted!
Jun 15, 2008 | RCA RCR311B Remote Control
Channel lock
Sounds like the unversal remote isnt programmed for your particular TV. See if the instruction manual gives the details for how to do that. If not, call them to see if they can walk you through it. If that doesnt work, go buy a big screen TV.
Apr 11, 2008 | Haier HTF20R21 20" TV
TV (RCA model F32705) stuck on one channel
go to setup in menu from fromt of set. do 1st time setup ...tell it you do NOT have a cable box. if it thinks you have one it deletes all channels but 3.
Jan 04, 2008 | RCA P46924 46" Rear Projection Television
Should i turn off my phillips DTR210 freeview box
It will be ok.....if you unplug at night, then it will need to reset
every time it is plugged in...........................T.
Dec 20, 2007 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
