After I turn the DVD on, it will play (you can hear it) but no picture shows on the TV screen. I do not have a manual so I cannot check this out as to operation.
  • idahomtnlady Aug 26, 2010
    The TV is Toshiba, an older one about 8 years old. The DVD is a CH DVD 320. I looked on the back of the DVD & there is no where to choose a channel.
  • 5,124 Answers
I need a bit more information to provide a solution. Is this a TV with integrated DVD or two separate units? If a stand-alone DVD, how are the two units connected. If you use separate video and audio cables (component, composite video or S-video), try new cables.
If HDMI or other cables do not help, then do you see the picture if you change the source? (Alternative sources will depend on the TV.)
If there is no picture, then look closely at the screen to try and determine the problem. If the backlight has failed, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing.
To diagnose a bad inverter or other board: For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the backlight(s) are bad (the number depend on the size of the TV) you need to remove the screen from the bezel of the TV then unwrap the edges. The backlights are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx .Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
Another way to test the backlight is with a known good inverter. Similarly a known good backlight can test the inverter.
I hope this helps.
Posted on Aug 27, 2010
  • 4,472 Answers
Do you have your tv channel tuned to the same channel/input that your dvd player is hooked up to in the back? If you give me the make and model of the tv and the dvd player I would be glad to assist you further if necessary. Here is a good diagram for connecting the dvd player to your tv:
http://www.tomselectronics.net/hookup.html
Thank you,
Lee
Posted on Aug 26, 2010
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | Televison & Video
My alba tv picture disappears but you can still hear it
see the cause and remedies:
No picture
  1. Make sure all power cords +video+audio are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
God bless you
Jul 16, 2012 | Televison & Video
White screen and black vertical lines over half of la26b450 model tv screen
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
May 29, 2011 | Televison & Video
DVD/VCR picture (and sound) are not on tv screen
Try setting the TV to AV1 & see if the dvd picture appears.There should be a button on the remote to change TV/video. Hope this helps.
Dec 24, 2008 | Sony SLV-D300P DVD Player/VCR
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
No picture
Lately I cannot get a picture when I turn on the DVD operation--the TV screen, as always, is on INPUT (Extension).....the unit show PLAY, but the picture does not appear--and the TV screen stays blue! The audio is on, but no video....
This is something rather recent. However, if I unplug the electric-power source for the DVD-player, then sometimes the picture does appear, though not always.
I have checked the manual but find no good answer there. Please let me know what to do....many thanks.
Aug 06, 2008 | GoVideo DV2150 DVD Player/VCR
No VCR/DVD Picture or sound
Your unit may have been switched to Progressive Scan mode, which a normal analogue TV can't recognise. Check your VCR/DVD manual for instructions to change picture settings and set it back to PAL TV.
Failing that try a new 3 conductor lead from unit to TV.  Also unless you yourself were actually the one who accidentally unplugged the unit, it is just possible that whoever did has not (for whatever reason)disclosed to you the full detail of what actually happened to cause it to fail. If it was in fact dropped or fell, pulling on the AV leads they could have been rendered useless or the unit itself might have suffered a Gforce-shock causing component failure or circuit board fracture.
All the best with this one
Anthony
Oct 17, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
