Question about Hitachi UltraVision 60VF820 TV
I put a new lamp in tv wont come on lamp light keeps flishing
  • 4,889 Answers
If the lamp light keeps flashing it usually means that either the lamp door has come loose /the existing lamp has burned out. The first thing to do would be to open the lamp doors(inner and outer) and make sure that they click into place. If problem persists then its time to replace the lamp.
Posted on Aug 26, 2010
What does the f1 light mean my bike wont run that light keep flishing
it is telling you there is a possible fault, i put an answer on here for same thing
May 02, 2014 | 2005 Suzuki Boulevard C50
I have a 42 inch toshiba 720 dlp hdtv, and it wont turn on. i press power to turn it on, it tries to fire up, the lights under power and lamp start blinkin green, and then orange, but then just stops and...
Tv "LAMP" LED light indication is blinking or lite up?The tv projection lamp insisde this tv now like 1 1/2 or 2 years already?Tv on and used daily like 4 or 5 hours everydays?Yes.The tv projection lamp life are over.The tv require a new tv projection lamp.Still have problems after this the tv board that call the Ballast board it is dead too,must require changing too.The Ballast board only job are to help to fire up the tv projection lamp and keep it lit.
May 01, 2011 | Toshiba 46H84 46" Rear Projection...
The power and lamp light keep flashing, and the T.V itself wont turn off unless unplugged,
The tv projection lamp life are over.Ur tv require a new projection lamp replacement.U used a remote,tries to turn the tv off?Might have dead battery in ur remote?Tries to push the manual button on the tv on and off see if that work.Than it is the remote.
Nov 23, 2010 | JVC HD52G887 52" Television
Toshiba 52wm48p projection TV keeps restarting.
Hi,It sounds like an issue with the board that powers the lamp it's called the ballast.When you put a new lamp in it takes more voltage than the old lamp ,so the ballast when it starts to go weak it wont be able to power it.The cost for the ballast is less than the cost of the lamp and it could be done by yourself,you can find instructions on youtube.Have a bless one!
Apr 15, 2010 | Televison & Video
Lamp went out, ordered new bulb and put in but TV did not come back on but the bulb light keeps flashing light orange. Sent new bulb back just in case it was faulty & ordered another 1. I just received...
Make sure lamp cover is put back in its position properly after bulb replacement.
If I have info about model and brand of your TV then I might offer better help to fix it.
Jan 15, 2010 | Televison & Video
I HAVE A MISUBSHI TV MODEL #WD57734. THE TV WENT OUT AND THE LAMP LIGHT CAME ON. i REPLACED THE LAMP AND KNOW THE LAMP LIGHT AND POWER LIGHT ARE BLINKING AND IT WONT TURN ON.
Try resetting the set, there is a reset on the front of the tv where the power button is located, just stick the point of an ink pen it it and it will reset itself, if this does not work make sure the lamp door is secure.
Dec 04, 2009 | Televison & Video
I had a bad lamp and replaced it.There wasno
Make sure that the lamp is put in place correctly. Ensure that the lamp cover is securely installed. Review your installation then reinstall.
Sep 24, 2009 | Toshiba Televison & Video
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Tv wont turn on
Had the same problem. turned out to be the power supply to the DM assembly. Had to put a power supply, board and a new lamp in. Tech said the lamp blew out the power supply and board. I think it's just a lemon.
Oct 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Hitachi UltraVision 60VF820 TV Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
