Question about Lanzar HTG244 Car Audio Amplifier
Amplifier Why do my amp all ways bust my speakers when i turn it up my amp is 2000 watts and my speakers or 1000watts i have 2 15 in my car when i play my music i can smell smoke and then it busts, my speacker , they or blow out.I have had 2 sets of 12s and 4 sets of 15s and bust them all what is wrong.
  • 1,512 Answers
HI Skimmie
Beleive it or not, you probably need a bigger amp for the levels you are trying to acheive. If you regularly crank it and the amp gets driven to clipping, the square wave produced when the amp runs out of steam will burn the voice coils in your speakers. Best solution is to be sure you are delivering CLEAN power, not distorted or overdriven. It can be a bit hard to tell at high levels. Putting an oscillascope on your speaker outputs and check for clipping at the highest level you run is a good way of checking. Then set your max levels for that so that you cannot overdrive the amp. Clean undistorted power wont burn your speakers.
If you have variable LPF or a crossover, check the frequencies you are using also., Cross them over too high, and you will cook the voice coils also
robotek
Posted on May 06, 2008
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have a 300 watt alpine 4 channel amp powering 4 x 6.5" kenwood speakers. My speakers can take up to 170 watts each. I have to turn my gain up all the way on my amp in order to get a quality bass...
Your amp is overheating as your speakers all combined are 680 watts, double your max output on your amp. Ideally you need a 1000 watt amp to do the job and for perfect sound as you should never have your amp up to max as it is more likely to blow quicker. The 2000 watt amp your are speaking of will do the job perfect, but you need to keep the gain down around 50% as you could blow your speakers. But yeah all together you are right, the 2000 watt amp will stay cool as doesnt have to work nowhere near as hard as the one you have currently.
Mar 02, 2011 | Alpine Car Audio & Video
I have a Lanzar 4000 watt amplifier hooked up to 2 12inch MA Audio subs. When I crank my car the green power light on the amplifier comes on, but after a second or two it changes to protection mode. I have...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to get an old school Opti Drive. .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-4000-watt-amplifier-hooked-up-2-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Jan 29, 2011 | Lanzar VIBE286 Car Audio Amplifier
I have 2 12 inch jl audio w7's with a kicker crossover and a powerbass equalizer 5 bands. i wanted to know if add a hifonics brutus 2100 d class amp to my subs at 1 ohm would it over power my subs. please...
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Dec 22, 2010 | Hifonics Car Audio & Video
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Car Ampli Problem
forget hooking this on a subwoofer. this amp produces only 50 watts per channel at 4ohms or 70 watts per channel at 2 ohms RMS...
If you try bridging the sub, it will only give out maybe 100watts bridged.
So..... if your sub is, lets say 1000watts RMS, youre just going to bust your amplifier to smoke...
Find a more decent and powerful amp. This amp is only intended for separates and lowend subs with an RMS of 80 to 150 watts
Sep 08, 2009 | Eclipse EA3422 Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
How would i conect a ep2500 amp two 2 subs @ 4 ohms, or 8ohms
hey" i got 2 behringer 2500 amps and i have 2 peavey speaker that are 4 ohms 2000 watts eachand want to mono the amp separte,and i want to run 1 amp to each speaker so can you help me?
Nov 26, 2008 | Behringer EUROPOWER EP2500 Amplifier
Application
I'm happy I can help a newbie. I remember when I was one and I'm happy to help you. First off, I nodiced that the fuse is only a 30 amp fuse. A quick way to see what is probably the max output of your amp is take the fuse value, in your case 30 and multiply it by the voltage you will be supplying it. Lets say you are just sitting with the car off the voltage would be 12ish volts. So your total assumed wattage is 360 watts. Which is an large amount less than the 1000watts listed. So watch out for that. Also, with subs you would want a mono-block class-d amplifier. If you need any more help at all, let me know. Good luck
-Andrew Hawkins
Aug 21, 2008 | Hitron HRA-4100B 4 Channel 400 Watt Mosfet...
Crate spa 400
you might need to see what your volts are if there 14.4 at the amp thats good but see what they drop to ....
Jan 01, 2008 | Crate SPA1600 Power Amplifier - SPA Series...
Lanzar HTG244 Car Audio Amplifier Logo
Top Lanzar Car Audio & Video Experts
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
