Question about Sirius Stiletto 2 Satellite Radio Receiver
My volume button on the side of my device does not work. A piece from inside the device has fallen off and it will not go back on. I do not have a warranty but is there some where I can take my device to get it fixed or is there a way that I can fix it?
I'm having the same problem... did you figure it out? Volume Down works, but Volume UP does not. As a result, volume is now all the way down, and I can't turn it back up.
Posted on Sep 23, 2010
  • m_rocco Feb 09, 2011
    I found out that you have to send it to Sirius for repairs. I am just gonna wait till I find a used one on Ebay for $60 or $70 bucks. It will be much cheaper!
Electric window button on 95 Lincoln Towncar has fallen in.
Can you get it out far enough to put a "C" shaped piece of plastic under it so it won't fall back into the hole? Or wrap some tape around it, or some string?
Jan 21, 2013 | 1995 Lincoln Town Car
On the Logitech mm50 Portable Speakers for iPod, the + volume button plastic cover has fallen off. Can I fix it myself?
Glue will not usually work---use something not sharp like a plastic wand to activate the micro switch---as far as the buttons they are usually a one piece part that is either melted in place or screwed--may be a little hard to locate.
Jun 10, 2012 | Logitech Inc MM50 Portable Speakers iPod...
All the buttons on my tv remote work but the volume, What do I do ?
Sounds like they are not touching the board inside the remote. for that take the remote apart reposition the board inside of it (careful not put fingers on board, sides only) make sure they are working and then put the remote back together.
May 13, 2012 | Sharp Televison & Video
Neither 0000 or 1234 work as Motorola t305 passwords
I wasn't able to locate any documentation on a factory reset, but if it is like all of their headsets, press and hold both volume buttons and the call button at the same time - hold it for 10 seconds and it should reset - IF it works the same. If it does, the default passcode is 0000
Mar 07, 2010 | Motorola Mobility Bluetooth Hands-Free...
The guitar lead plug has fallen inside.
The safest way to fix this is to take the amp apart to get at the jack. If the jack is a solid black plastic shape, then you should replace the jack completely. Otherwise you should have access from the side of the jack to remove the piece of hte plug that broke off.
Dan
Feb 18, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Reset Button on Tag Heuer watch has fallen off
That's right, nothing will hold that button in place as clipspring has fallen off or broke and retains inside the watch. Do not wind or wear your watch now as that clipspring is freely floating inside movement and can damage your watch geartrain.
Find your nearest watch repair shop and ask to refit button with clipspring. Watchmaker will know how to do the job and how to get rid of any broken remains if there are any.
Don't forget to rate, please.
Jan 11, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Gas-spring mechanism has stopped working on my 2006 quinny buzz :(
I sent my frame to dorel and they fixed the same problem quite cheap to do if you remove the wheels etc they were quick to send back too phone them on 01842763281
Sep 12, 2008 | Quinny Buzz Jogger
Motorola S9 headphones
Ok, here we go. I spent about 3 hours on this issue and sacrificed some functionality on my headphones to solve the low volume music problem.
Clearly some people have had success with less drastic measures so I would suggest trying the following steps in order before dismantling the unit.
  1. Attempt to dry out the headphones in case moisture is the culprit.
  2. Call Motorola. If you are still covered under their 1 year warranty, make it their problem. You get a new set and all is gravy (at least until the new ones poop out). Repeat as necessary.
  3. Attempt a reset of the headset. This was mention in solution 8 and could well work for you.
  4. Try to override the volume up (explained in solution 6)
  5. If none of this works, try the steps outlined in solution 10. In my experience, there was gluey goop everywhere! This might be affecting the connections and causing the low volume.
  6. If none of this works (as was my case), proceed to disassemble the headset in the following manner...
I found that after disassembling, and creating a manual connection between the contacts for the volume + button, the volume would still remain at minimum. Therefore, I believe that instead of the moisture killing the volume + switch, the volume - contacts have corroded in the closed position. This solution will remove the ability to use the volume - button. But, you will still maintain you ability to make and answer calls with the phone button if it is currently operational.
  1. Slowly peel back the red silicone covering over the back of the headset near the power switch. Note: the flap covering the mini USB plug will release once the casing has been opened.
  2. Reveal the four #0 phillips screws on the inside surface of the headset body. Remove them and set aside.
  3. Using your nail, or a flat blunt object (like a butter knife), pry open the casing starting near the mini USB port.
  4. Once it all is opened up into two casing pieces and exposing the circuit board, find the 6 pin JST connector for the left side of the headset. The colors are coded as follows: black for ground, orange for volume -, red for phone button, yellow (almost gold) for volume +, and the last two (I believe they were green and blue) are for the speaker.
  5. Cut the orange wire (if black is pin 1, orange would be pin 2). This will prevent minimum volume problems in the future.
  6. Power on the device without touching any open contacts on the circuit board.
  7. Connect the S9 to your phone or whatever you play music through.
  8. While the music is playing, use a strand of electrical wire or similar conductive material to briefly make contact between the black and yellow terminals on the back of the JST connector. This will replicate the volume + button allowing you to adjust the volume up. I set my volume to about 80-90%. If you set it too high, you will have to make brief contact between the black and orange wire to adjust the volume down.
  9. Close the headset casing and replace the screws.
  10. Glue the red silicone padding down.
Wrote this will jammin' to Chant a Psalm by Steel Pulse. Good luck bitches...
May 15, 2008 | Motorola Mobility S9 Headphones
Controls
the sensor for remote has fallen off its usually connected to a 8 inch wire which fell back into system pull the sensor wire forward the way to get into tv 3 ways front pannel pops off sensor is set at front
there the back of tv
then theres threw the
Mar 19, 2008 | Apex Digital GB5108 51" Rear Projection...
My PSP the new version
do you mean the four buttons or the joystick? If it's the joystick it could be the piece of jelly/plastic that connects it to the motherboard
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Sirius Stiletto 2 Satellite Radio Receiver Logo
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
