Question about Volfenhag ZX-8300 Car Audio Amplifier
Protection light after being installed my amp worked fine, but after a while it shut off and the protection light came on. so i uninstalled the amp. what must i do to get it to working again. and can i have just this amp installed to work with all the speakers in my car/ thank you very much for your help in this matter.
  • 631 Answers
If the amp goes into protection with no speakers wires connected to the amp and no signal cables connected to the amp, the amp probably has shorted output transistors.
If that's the case, they would have to be replaced. Most people simply have the amp repaired by a qualified tech. If you want to try to repair it yourself, read the following page:
Amplifier Repair Primer
If the amp failed after only a short time, the speaker ohm load may have been too low. If it wasn't lower than the amp is designed to run, the amp may not be suitable for your needs.
Posted on May 06, 2008
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
May 15, 2013 | Jensen JPA600D - 600 Watts Digital Mono...
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Suddenly my pc re-boots when I plug my ipod into the front usb.
uninstall service pack 3 and ignore it when it asks you to re install it. go to add remove programs and uninstall it. obviously it worked befor. that is the solution. you dont need sp3 anyway.
Jul 18, 2009 | Gateway Computers & Internet
Amplifier protect circut is on and wont shut off
Mar 20, 2009 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Amp is shutting off after 10 min of driving!! please help!!
Does it happen at all volume levels?
What is the gain setting on the sub amp?
Have you checked for 12V @ remote turn on after problem occurs?
Sounds as if the remote turn on relay inside the amplifier is losing signal, or has become damaged. If the protection light does not light up, the problem is not thermal, shorting, or high/low voltage.
The amplifier is in need of repair. This is not an end-user fix. Looking at about $50 to repair.
Thanks for using FixYa- a FixYa rating is appreciated!!
Feb 18, 2009 | Profile BAJA HA700M Car Audio Amplifier
Install MS office home and student 2007
Shut down any active protection software such any antivirus, antispyware, antitrojan, or registry monitoring software.
Try to Unistall by using the install disk. It should detect a previous installation and ask if you want to Install, Repair, or Uninstall.
If that fails, download and run CCleaner - Use the Cleaner and Regisrty modules default settings
Reboot, and shut down active protection software.
Download and run Windows Installer CleanUp Utility.
Remove the applicable entries.
Hope this helps - good luck!
Nov 01, 2008 | 10 10 Computer Network adapter Cable...
Protection light
either you are playing too loud or you have a malfunctioning protection light. does your amp seem to get excessively hot, as long as it doesnt, then your problem is prolly just the light itself...
May 11, 2008 | Car Audio & Video
Amp protection light
Hi again, Looks like you posted twice, in any case pls have a look at your other post @
Aug 15, 2007 | Sony XM-2002GTR Car Audio Amplifier
Volfenhag ZX-8300 Car Audio Amplifier Logo
192 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
