Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE refrigerator side by side model #GSS25JFPDWW is freezing the items in the fresh food section. The repairman said that there is a flap behind the damper cover that is not working and that I needed to order a new flap. The flap adjusts the air that is flowing from the freezer to the fridge. I looked on line but do not see a flap as a part -only the damper cover. What part should I buy to repair the fridge?
  • GE Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Refrigerator inside not getting cold enough. A GE refrigerator side by side.
If it is just the fresh food section and not the freezer. Check out this link to see a GE condenser problem. Make sure to clean that condenser once a year. In most cases when the damper assembly flapper door goes bad in the fresh food section, the fresh food side will start to freeze your food. The next thing I would check is what John is talking about. Pull the freezer back panel off to see if your evaporator coil is frost over. When this happens it will restrict air into the fresh food side(refrigerator side). Click Here to see what a defrost problem looks like.
Jun 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Where do I find the model number on my Hotpoint
In the last few years GE has placed the models serial label on the top center, top left or top right of the fresh food section. Older models had it behind the fresh food door at the bottom or behind the grille. Also there were a couple of years they placed it behind or to the side of one of the lower drawers.
Sorry about all the different locations. That's just how they did it.
Thanks.
May 25, 2010 | GE Hotpoint Top-Freezer Refrigerator
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
I'm having problems with my Adora fridge. First, the contents in the crispers started freezing. The storage tank behind the drawers seems to be frozen. Now the water won't dispense. Ice is being made...
Your model has a WR60X10132 or 10055112 Damper and Fan that regulates temperatures between the freezer and fresh food compartment. The part has been recently updated. Refrigerator air inlet cover/damper kit with fan motor. Damper and fan assembly has been updated to prevent freezing in the refrigerator.
(The manufacturer has replaced part number wr60x10132 with this item, part number WR49X10091.) (Manufacturer part number WR49X10091 is RepairClinic item number 1055112.)
BRB with photos and locations. Sea Breeeze
Jan 23, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
