Question about Amana 3.2 cu. ft. Top-Load Washer
Need to replace amana wash machine belt - Amana 3.2 cu. ft. Top-Load Washer
  • 176 Answers
D&L stor
Posted on Aug 26, 2010
Amana washing machine will not spin keeps shuting off
If it's a front loader, check the bearing, they wear out.
Nov 22, 2013 | Amana Washing Machines
Amana LW8303L2 will not spine
http://www.washerhelp.co.uk/washing-machine-repairs.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Belt replacement on these is a slightly intimidating job to the uninitiated, but possible.
http://www.american-appliance.com/se...stic-Chart.htm
http://www.applianceaid.com/amana-wash.html#belt
Lots of pictures and help at these sites.
Main thing is use ONLY the factory-authorised replacement belt on these. It is designed to have the right amount of slip/grip to enable your washer to work properly. This is CRITICAL on Amanas.
Apr 14, 2010 | Washing Machines
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Tighten the belt on an Amana washer?
The belt should already be pretty tight after wrapping around the barrel and the motor pulley. The belt may be worn and should be inspected and probably replaced.
To prevent similar problems in the future I suggest you be aware of how big of a load you put in the washer.
Mar 13, 2010 | Amana 3.2 cu. ft. Top-Load Washer
I need to replace the belt on my Amana ALW480DAW. The other one burnt up and broke. I have the new one. Do you have a diagram I could view to help me install the new one?
I used the following links:
http://www.partselect.com/ModelFrames.aspx?ModelID=29693&ModelNum=ALW480DAW&mfgModelNum=PALW480DAW&ManufactureID=1&Selected=31971&Position=7&mfg=Maytag&Type=&Mark=7
Oct 21, 2009 | Amana ALW480DA Top Load Washer
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
