Question about Thermador PRG304US Gas Kitchen Range
I need to replace the Burner Control Valve for my Thermador gas oven PRG486GDUS part number 415500. The part is discontinued and seems to be no longer available. I have exhausted my sources. Any suggestions?
  • 176 Answers
Look at D&L stor
Posted on Aug 26, 2010
Stove and oven will not turn on. No digital display also.
check all fuses, the power cord, the circut breaker and if you have a multimeter see if you have voltage at the plug in the wall
Jun 23, 2008 | Thermador Kitchen Ranges
Parts breakdown
Thermador ranges use Bosch parts, or perhaps even are made by Bosch (my strong suspicion). The Bosch part you are looking for is "Bosch (OEM) Part #00369988". It should be available under that number.
Dec 20, 2013 | Thermador PRG486GDUS Gas Kitchen Range
Need discontinued burner valve for GCV36G
You can try an appliance parts supplier. There might be a crossover to a current part
May 08, 2013 | Thermador Kitchen Ranges
Model # PRG486GDUS The large oven does not heat up appropriately. There is only small blue flame from the tubular burner - flames the size of bb's. Puffing sound from the burner - gas does not...
I think what you are describing is only the pilot light running. If there are no flames at all from the burner, or it lights, but then fails very quickly, it may be your safety cutout is not operating as it should. When the oven lighting mechanism lights the gas the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressore in the sensor pipe, the valve won't open and there is no gas to the burner.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that's not an issue, you can just coil any extra pipe up somewhere between the burner and the valve.
Jul 07, 2011 | Thermador PRG486GDUS Gas Kitchen Range
I'm looking for discontinued part # 415500 and part # 415499 for a Thermador range.
I am not affiliated with this site but I was able to find your parts here: http://www.appliancepartspros.com/partsearch.aspx?pn_=415500
Sure hope I was helpful.
Please rate this if when you get a chance.
Dec 13, 2010 | Cooktops
I have a Thermador PRG304US. The far right burner
I am having the same problem. Have you found any solution?
Jul 03, 2010 | Thermador PRG304US Gas Kitchen Range
The left rear burner does not work. Following a recent cleaning, nothing happens when I turn the knob. Gas does not flow and the igniter does not click. The remaining burners all work normally.
Sometimes when cleaning water gets into the ring and the sparks stop but this usually clears up when the unit is dryed out. as for no gas I cant help
Jun 14, 2010 | Thermador PRG486GDUS Gas Kitchen Range
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PRG304US Gas Kitchen Range Logo
218 people viewed this question
Top Thermador Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
