Question about VeriFone 250 Matrix Printer
What are the windows printer commands that the generic driver is looking for?? I can not figure it out. Thanks.
    Top Expert:
  • VeriFone Master
  • 76,164 Answers
It is unclear what u are asking here, are you saying the computer program is looking for a driver and it is not found? if so u will need to go to the support site of the printer manufacturer and download the driver at their site.
Posted on Aug 26, 2010
Printer is too slow to print once the command is given from PC
Hi
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. or The printer might be printing slow , pausing in between print jobs , or intermittent printing. The symptom solution is mention below, read and follow the instruction.
Solution 1
After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model. Insert the Driver CD as prompted and by default it will select the DOT4 HP LaserJet2420 Port.
Solution 2
  1. Insert the HP LaserJet 2400 print series CD-ROM.
    NOTE: If the HP Software does not automatically start, click Start , Run , and then Browse . Browse to the CD-ROM drive at the top of the window under look in and select Setup.exe .
  2. Select Modify Installation . Figure 1: Modify Installation c00369540.gif
    NOTE: If Modify Installation is not available See Modify Installation is not Available.
  3. Select the Language of your choice. Figure 2: Select Language c00369541.gif
  4. Click Next. Figure 3: Setup Wizard c00369542.gif
  5. Verify Reinstalling an existing printer is selected. Under Select the port for this printer , choose USB001 or Dot4_00x and click Next . Figure 4: Choose Port c00369543.gif
  6. Select desired Features and click Next . Figure 5: Select Next c00369544.gif
  7. Click Finish . Figure 6: Select Finish c00369545.gif
Uninstall options
  • First verify if an uninstall options is available. If an uninstall option is available under Start, Programs, HP LaserJet 2410 2420 2430 , use this method to uninstall the printer.
God Luck
Sep 09, 2011 | HP LaserJet 2420 Printer
How do we embed into a Windows report, commands for a Tec B472
Hi Gilles483,
If you want to use a printer in windows, create a Generic text printer in the correct port and send the commands.
Nov 19, 2009 | Toshiba TEC B-472 Thermal Label Printer
My Zebra LP-2844-Z won't print, says spooling, printing, deleting
try this--open the control panel then open system & maint then admin tools. open services then find the print spooler svc and right click then restart. close all jobs and print windows first then try again
May 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
Can't find driver for Epson TM-H6000 for Vista 64-bit OS
hi.
hi i have a same problem as u have. but for now i am using generic driver using generic text drive only. and pls dont forget to keep ur port as com1 plus change ur bit to 19200 otherwise that also will not work.
Feb 27, 2009 | Epson H6000II Thermal Printer
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Speed and Cleanliness
You can follow the following steps to clean the spooler on your computer that might speed up the printing speed .
  1. Open a Command Prompt window >
key the command net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also.
4. In the run
type : c:/windows/system32/spool/printers: delete any files there.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
  1. There might be two entries names Version-2 and Version-3 under drivers: click the plus sign against them and remove everything under them.
  2. Then click the plus sign against PRINT PROCESSOR, which is under DRIVERS and make sure there is only one entry i.e., WINPRINT. If there is any other entry, just remove it.
The spooler cleaning is complete
Apr 11, 2008 | HP PSC 2175 All-In-One InkJet Printer
How to install HP Laserjet 6L Gold if installer CD is lost
I have a HP laser 6L gold printer, it is working properly. Now the problem is I had lost my Installer/Driver Floppy, I therefore unable to install my Printer on the PC. I am using Windows 98 SE Operating System. Win98 has a self 6L PCL Driver but I want to install actual Driver. May I request you to kindly provide the same.
Thanks!!
Ravi
swapan32@hotmail.com
Apr 10, 2008 | Office Equipment & Supplies
SRP-350 barcode CODE 128 C printing problem
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Mar 28, 2007 | Samsung SRP 350 Thermal Printer
Epson stylus c86 series-paused
Go to your printers/faxes folder and right click on your printer and see if it's offline or similair. If no joy, right click on it and uninstall printer. Re-start your PC and let Windows find it again, but make sure the manufacturers driver automatically installs and not a Windows generic driver.
Dec 01, 2006 | Epson Stylus C86 InkJet Printer
VeriFone 250 Matrix Printer Logo
Top VeriFone Office Equipment & Supplies Experts
George Mclaughlin
Willie Cooper
Willie Cooper
Are you a VeriFone Office Equipment and Supply Expert? Answer questions, earn points and help others
