Question about Intel Motherboard
Connecting how do i connect Ground, L-Out, R-Out, L-Ret and R-Ret cable into the motherboard? get to me asap!
  • neo12412003 Feb 26, 2009
    i have 9 pins
    and i have like this:
    MIC in
    Ground
    mic biass
    spkr R
    spkr L
    return R
    return L
    i have Gigabyte Motherboard and i don`t know where to connect the the cables,need fast response if posible
    tnx!!
  • 24 Answers
Hi Hello88,
motherboard have different designs depending on the manufacturer and model, I highly recommend that you consult your motherboards documentation on how to locate the different connectors in the board. In case you don't have the manual, try downloading it from the manufacturer's site. The tricky work begins when you really can't find the documentation for your motherboard, as you'll have to find the connector by actually looking on the board, if you have a magnifying glass and flashlight, that would help seriously. Most manufacturers put visible markings on the the board, either words, abbrevations or symbols, audio connections are often a group of 4 connector pins, perhaps you can start looking for that, some boards have multiple grouped pins for audio connections which are designed to cater different types of audio cable connectors. Hope this helps.
Cheers and best regards,
Posted on May 06, 2008
I have 8 pins on chassis mic in,mic power, 2*grounds,L and R out and L and R ret but my mobo manual only provides homes for 5 pins leaving out 1 ground and L and R ret can anyone help me find homes for...
If the user manual isn't giving you locations for those wires then they are not supported or that board is expecting a different type plug to work properly. Check the motherboard manufacturer website for a user manual download.
Dec 08, 2011 | Gigabyte GA-EX58-UD3R Motherboard
Connection of audio leads
Here is the link to the Gigabyte site to your specific motherboard. The only place that will have those pin locations is the user manual. Not all motherboards support all chassis designs and at times modification of the connectors is required in order to get the connections. Check the User manual for the actual pin outs.
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
Where do i connect front panel MIC POWER, MIC IN, GND, R OUT-R RET, L OUT-L RET. MOTHERBOARD IS ASUS M2N-MX
I've attache a picture to show you where the jumpers are located on the board, and an explaination of what gets plugged into what.
Good Luck
Thanks
Mark
Feb 15, 2010 | ASUS M2N-MX Motherboard
JAUD1
download manual from here :
http://www.msi.com/index.php?func=downloadfile&dno=3989&type=manual
see on page 34 :
Front Panel Audio Connector: JAUD1
Note : The odd pins are on one side and the even ones on the other side.
Oct 05, 2009 | MSI K8N Neo4-F Motherboard
WANT TO KNOW WHERE TO PUT MY AUDIO LEADS BACK IN THERE PINS ON THE MOTHERBOARD
Mic In to pin 1; Gnd to pins 2 and 3; R Out to pin 5; Ret R to pin 6; L Out to pin 9, and Ret L to pin 10. Remove the jumpers on pins on the motherboard before placing thses wires.
If it is an internal speaker connection
SPK1: Internal speaker header Pin Signal Name
1 SPKR
2 NC
3 Ground
4 +5V
Hope this helps
May 09, 2009 | Computers & Internet
Motherboard
clarification request:
be spcific problem like what pin and connected to the......
Jun 26, 2008 | HP Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
