Question about Acer Aspire One PC Notebook
Have an Acer "one series" laptop notebook. The small one. Need to know what the function keys along the top of the keyboard doe and how to use them.
    President:
  • 2,571 Answers
How do i turn on the scrolling on my acer laptop
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again
May 13, 2012 | Acer Aspire 5100 Notebook
I cant get any wireless signals because its says wireless capability is turned off it says to use the switch to turn it on but there is no switch. how do i turn it back on
Depending on your operating system, you can often just troubleshoot the problem and Windows will automatically turn your wireless adapter back on. If this doesn't work, it's likely that there's a physical switch on the laptop that needs to be in the "on" position otherwise it won't work. It may also be a function key combination. If this is the case, look for a little wireless symbol on your F1 through F12 buttons, then hit the function key "Fn" (usually right next to Ctrl) along with the appropriate wifi key and it should re-engage.
Mar 05, 2011 | Acer Aspire 4520-5582 Notebook
Where is the volume control on the acer aspire 5534?
Press the Fn key in the bottom left of the keyboard, and while holding, press the up arrow as needed to increase sound.
Mar 01, 2011 | Acer Aspire 55345410 Notebook
Replace keyboard on acer 8100 series laptop
Replace the inside of the keyboard with a new piece. One of the major problems with Dell keyboards is that the plastic pieces holding the keys in place become loose or broken. You can find a cheap keyboard from Papatek.com or an electronics store. Simply take apart the new keyboard, pull the keys off your keyboard, lay the plastic piece on top and replace your keys.
http://www.papatek.com/Acer-Keyboard/Acer-Travelmate-8100-keyboard.html
Jul 23, 2010 | Acer Ferrari 4000 Notebook
The screen quit and I need to turn on the external monitor port
Look on your keyboard, along one of the top 2 rows you'll see some symbols as alternatives to the main key function. One will be a small picture of a TV screen.
Press the key Fn and the small screen key together.
May 12, 2010 | Acer Aspire 3610 Notebook
Where is the fn key on keyboard acer
Laptops have a Fn key in the lower left side, next to the CTRL key. Says Fn on it.
Desktops don't have a Fn key. They have special function keys along the top numbered F1 through F12.
The windows key is the one you find on desktops, and on laptops, in the same place, the key says Fn. They are not the same.
Jul 01, 2009 | Acer 91.63X07.001 Keyboard
Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Jan 25, 2009 | Acer Aspire 5920-6727 Notebook
How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Sep 23, 2008 | HP Compaq Presario V5000Z Notebook
Wireless keyboard and mouse
on your keypad there is a button ' fn' (normaly on near the windows key, blue in colour) which when pressed along with another one on the keypad (somewhere in the top row of the keypad) activates this function, what you have to do is a press these two key again simultaneously to de-activate this function. the second button or key will most likely be paired with one of the f_ keys
Sep 08, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 3000 Series Numerical Keyboard/Function Key Problem
if using XP go to my computer, right click>properties>hardware tab>device manager>look down list for keyboard, click '+' sign and highlight your keyboard and right click and select uninstall. Restart the notebook and the keyboard will be installed automatically along with the drivers and should set it back to default.
May 21, 2007 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
