Question about ASUS P4P800 SE (890552603657) Motherboard
Connecting How do I connect the Ground, L-Out, R-Out, L-Ret and R-Ret cable?
Download the Manual from
http://support.asus.com/download/download.aspx?SLanguage=en-us
as PDF format.
Posted on May 06, 2008
Connection of audio leads
Here is the link to the Gigabyte site to your specific motherboard. The only place that will have those pin locations is the user manual. Not all motherboards support all chassis designs and at times modification of the connectors is required in order to get the connections. Check the User manual for the actual pin outs.
Dec 08, 2011 | Gigabyte GA-EX58-UD3R Motherboard
Hi! i am using Intel DG33FB motherboard, i need the information about the connectivity of front pannel audio. for this it is Realtek HD audio port. i am having 5 cables set for the front pannel...
The L&R-Ret2&3 are common so only one needs fitting so for the speakers you only need to connect 3 cables. R-Out, L-Out and one return (either L of R). I'll comment back shortly on the mic pins for you.
Dec 23, 2010 | Computers & Internet
What do i do with the earth cable on my technics to stop the humming?
If you are connecting it directly to a HiFi amplifier, connect the ground lead of the technics to the ground termination on the back of the amplifier.
If you are connecting to a Dj Mixer, connect the Technics ground lead to the ground on the back of the Dj Mixer.
Make sure the ground is connected securely and will not fall off. To check this, after connection give a light pull on the ground cable. If the lead comes away, reterminate (connect).
Nov 09, 2009 | Technics SL-1210 Turntable
WANT TO KNOW WHERE TO PUT MY AUDIO LEADS BACK IN THERE PINS ON THE MOTHERBOARD
Mic In to pin 1; Gnd to pins 2 and 3; R Out to pin 5; Ret R to pin 6; L Out to pin 9, and Ret L to pin 10. Remove the jumpers on pins on the motherboard before placing thses wires.
If it is an internal speaker connection
SPK1: Internal speaker header Pin Signal Name
1 SPKR
2 NC
3 Ground
4 +5V
Hope this helps
May 09, 2009 | Computers & Internet
Motherboard
clarification request:
be spcific problem like what pin and connected to the......
Jun 26, 2008 | HP Computers & Internet
Connecting
Hi Hello88,
motherboard have different designs depending on the manufacturer and model, I highly recommend that you consult your motherboards documentation on how to locate the different connectors in the board. In case you don't have the manual, try downloading it from the manufacturer's site. The tricky work begins when you really can't find the documentation for your motherboard, as you'll have to find the connector by actually looking on the board, if you have a magnifying glass and flashlight, that would help seriously. Most manufacturers put visible markings on the the board, either words, abbrevations or symbols, audio connections are often a group of 4 connector pins, perhaps you can start looking for that, some boards have multiple grouped pins for audio connections which are designed to cater different types of audio cable connectors. Hope this helps.
Cheers and best regards,
May 06, 2008 | Intel Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
97 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
