Question about Refrigerators
I have a KSS048QMB01. The problem is the right side (refrig side) has lost its light and display. The refrig still stays cold and the light bulbs are ok because I have taken them out and tried them in another fixture.
  • jzigrossi Aug 26, 2010
    Where is the control board located and do you need to be a brain surgen to replace it?
  • Refrigerators Master
  • 1,711 Answers
We have this problem also with other users.
The electronic Display Board It may very possibly be the problem The board is with part number 2320696 .
Their is a small posibility that the main control board may have a problem sending power to this board but not less posible than above.
The main control board is part number 2307028.
And the parts can be found at the locations listed below. If you have more questions or need help feel free to let me know, Thanks,
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Posted on Aug 26, 2010
The freezer runs good but the fridge is not cooling
check for movement of the damper vent door between the refrige and freezer compartments if its frozen in place,defrost it as it can't throttle cold air in from the freezer,if this is ok and you have lost lights and replaced them and now they just "strobe" or flash dimly and the digital read-out display if so equipped in the refrige section and possibly there's a relay clicking in the rear of the unit too,then its the main-board thats defective in the rear area of the fridge
May 13, 2010 | GE HSM25GFTSA Side by Side Refrigerator
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Refrig shut off and will not restart - light bulbs still working
this refrigerator sounds like a 'frost free' type, and as such can, usually, only be repaired by the manufacturer. local refrigeration engineers cannot get the parts. your fault sounds like a PCB (printed circuit board) has gone, which only the manufacturers have in stock.
Jan 25, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refrigerator is hot
IM NOT UNDERSTANDING YOU PROPERLY IS THE FOOD IN THE REFRIG STAYING COLD.PLEASE GIVE MORE DETAILS ON YOUR PROBLEM AND NO THE LIGHT BULB WILL NOT CAUSE THAT.MOHAMED
Sep 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
