Question about Bose 901 VI Main / Stereo Speaker
Connect bose 901 VI eq to yamaha rx v2700 - Bose 901 VI Main / Stereo Speaker
harishu
  • 18 Answers
SOURCE: how do i connect the bose 901 system to my yamaha rx-v2700
how about you connect your pre-amp out to eq-in and eq-out to aux ?
Posted on May 22, 2008
SOURCE: Connect Bose 901 VI EQ to a Harmon Kardon AVR 247 Amp
Similar problem...I came up with a solution with help from Onyko. For my receiver, at least, the bottom line was that the output from the equalizer MUST go to 'Receiver, Tape In'! Since that is the ONLY input source from the equalizer, you must combine elsewhere. Part of my setup included the Radio Shack Audio/Video Selector box which costs $21.99...you might not need it, but in my case, I couldn't plug all components into the back of the receiver and have them go through the equalizer.
Since I have a satellite receiver, DVD player and TV, that I want to route through the equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Posted on Dec 21, 2008
dunnbiker
  • 8546 Answers
SOURCE: Marantz sr8002
I wrote this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great! With one caveat - My receiver actually has 5.1 analog Outputs so I can drive up to 6 external amplifiers if I want to (I drive 4). IF yours does NOT (*) we have to be creative in extracting the front two channels from your multi-channel receiver. The obvious alternative place would be at one of the few OUTputs on the back, assuming you have one free to use.
* I can't find your exact manual so I have to extrapolate features.
I see on the SR>6003< there are Pre Audio OUTS so I'm betting your receiver does, too.
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out; (or VCR or Tape Out if you don't have Pre Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receivers speaker level setup.
*** If you use a Tape or VCR Out you will NOT be able to SELECT the source you use for the 901 Pre-Outs for listening, or else the 901's will not get any sound sent their way. DO NOT USE the monitor switch for that source.
Posted on Apr 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do I connect the
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
Posted on Jan 17, 2011
dunnbiker
  • 8546 Answers
SOURCE: I have harman kardon AVR
I have a setup similar to what I think you're trying to do and it works great!
You're in luck because you have a full complement of pre-outs. You'll need a separate amp for the 901's.
First some background.
The use of 901's Active EQ (or any external proxcessor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's. I use a Carver MT-200.
Run it with the Active EQ between the receiver Front L and R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> new amplifier IN.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and leave it alone. Run through your speaker setup routines on the AVR. After levels and distances are set the AVR will be the boss of the 901's. With 901's don't even need subwoofers but they don't hurt. If you do have subs I recommend sharing the LFE with the 901's.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up a movie like Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media! I advise having the 901's share LFE with any subwoofers you might have.
http://www.retrevo.com/support/Harman-Kardon-AVR-230-Receivers-manual/id/386bh145/t/2/
Posted on Feb 04, 2011
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Bose 901 eq connect to mixer and amp
how to connect bose 901 speakers to mixer. help me
Mar 29, 2012 | Bose 901 VI Main / Stereo Speaker
I am using the "
http://www.retrevo.com/support/Yamaha-RX-797-Receivers-manual/id/320ag612/t/2/
I assume you've placed the Bose Active EQ in where the Pre-Out >> Main In jumpers were. Do you have the return from the Bose Active EQ going back into the Main In so it can continue to the Sub Output.
Or do you have the Bose EQ Tape Switch activated incorrectly?
Feb 03, 2011 | Yamaha RX-797 Receiver
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
Two solutions:
Now imagine this:
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer
Hi Mark, had a look for a manual on your Yamaha, but not got to one as yet. Does it have any RCA connections on the back marked as preout prein? best place to put the 901 EQ is in line with L and R front channels at this preout prein point.
Some amps DO NOT HAVE IT. If our does not, then you could connect it in the tape loop, tape out(rec) to input on the EQ. and the output of the EQ connected to tape in(play), but connected like this, the EQ would affect the tone across all channels(unless you are just running a stereo rig, then this way works great!!) Try this and you may just have solved you problem anyway.
regards
Graeme
Mar 28, 2008 | Audio Players & Recorders
How do i connect the bose 901 system to my yamaha rx-v2700
Mar 07, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
70 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
