Question about Toshiba 50A61 50" Rear Projection Television
I plug it in and it clicks and the power light flashes
    Champion:
  • 453 Answers
U have a power supply problem the most common problem on this tv is the convergence ic , but i would recoment u to take it to a repair shop this repair in this tv is very hard
Posted on Aug 26, 2010
  • biggrobdogg4 Aug 29, 2010
    could it be the relay switch
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
Monitor is slow coming on then when on website clicking out of second tab flashes black
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
All lights flashing rapidly
Indicators, Codes, and Messages
Dell PowerEdge 1800 Systems Installation and Troubleshooting Guide
http://support.dell.com/support/edocs/systems/pe1800/en/it/r2053c20.htm
Aug 06, 2012 | Dell PowerEdge 1800 Server
The power/standby light blinks green 4 times, the tv clicks, then repeats flashing and clicking...no pwer
the problem on you tv is the fan is not working this is the big fan you see on the back of your unit , is very ease to replace take cover off and you would see the fan , when you look the tv from the back look at you left and there is , you may want to call sony that way you would get the right part , i have fix a lot of this tv with this problem
Jan 24, 2012 | Sony KDF-E42A10 42 in. LCD Television
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Toshiba 50A61 50" Rear Projection Television Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
