Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Water is continually dripping from the unit when it is not running
  • 40 Answers
Replace the float and solenoid
Posted on Apr 04, 2011
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
I have the Kenmore top-mount 106.76232402 leaking
hi.turn water supply to fridge first.cont drip might be a faulty valve.hope this helps.Ali
Jun 26, 2012 | Kenmore Refrigerators
Water leaking from icemaker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2011 | Kenmore Refrigerators
Water from ice maker running through freezer and on to floor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and divert the water. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Dec 03, 2009 | Amana Refrigerators
Water driping inside from ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
My Kenmore icemaker seems to be leaking water under the icemaker and it drips and freezes
Aug 10, 2009 | Kenmore Refrigerators
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
46 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
