Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
My fridge whirlpool gold side by side is leaking from the over flow tray. I drained it & it was full with in 40 min's or so. the fridge/freezer closes tight & everything in the fridge is still frozen. a couple weeks ago the light bulb blew out in the fridge where the controls are. when I went to replace bulb the controls turn off & seems like there is a short there. the bulb blew & took the control lights with it. when i removed the bulb the control panels came back. same thing happened when I tried to replace the bulb w a new bulb so I just don't have any bulb in there now... all feedback appreciated!
  • 4,070 Answers
When the water filter is stopped up it will bypass to the drain pan.
Posted on Aug 26, 2010
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Refrigerator Odor
sounds like fungus in the drain tube
unplug fridge p\and pour some bleach in the freezer
it stinks but it will kill the smell
after 10 min or so take fridge to patio and hose her down water will not hurt the fridge it will however clear the drain lines
and it might be a good time to clean the coils and the colection tray under the back of the fridg any way
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water buildup in the fridge, dripping in from the freezer
This could be a bad thermostat. If your thermostat never closes it's swith then the defrost element never comes on and you get the problem you are having. Easy fix. Do you know where your timer is and can you retate it?
Jul 12, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Whirlpool gold
hi thanks for the question it looks like the drain tube is clogged up you can clean this out first turn off fridge let thaw pull back cover off vacuum any dirt you find find the evaporation tray that's where the melted ice is suppose to go buy a small plastic hose to shove up the tube clean out should be ok the appliance doc
Sep 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool gold, freezer on top, single door
hi thanks for the question the drain system is clogged the drain hose from the freezer to the drain tray undre neath the fridge by the compressor is clogged you may have to shut down the unit to let the ice melt that has caused this problem get a small plastic hose from a hardware store and shove it up the drain dose and blow air up the hose till its clear that's why you have to shut the fridge off for 24 hrs to allow the ice to melt then blow the air thanks the appliance doc
Sep 02, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
