Question about Kenmore Washing Machines
I have a front loading washer - have had for 8 years or so. Began smelling moldy smell - noted little stuff around the holes in the rubber seal around the door. Then I began to pull it back and found mold all around the hole under the seal. I have done a wash with bleach - which I never use. Didn't help. What to do? Can a repair person take the rubber seal off - looks like it needs a good cleaning? How to prevent in the future?
  • Kenmore Master
  • 2,128 Answers
You need to wipe down that part of boot seal after every wash,tide has tablets that you stick in the washing machine and run it through and it removes the smell but it will come back if you don't wipe it down.also if you are using to much detergent that will make it stinky and eat the spider gear and if that happens it's new washer time,you hear a loud banging noise when it's in spin.call your local appliance store and ask them for the pack of tablets,it's like washer magic or something like that,good luck.let me know how you make out
Posted on Aug 26, 2010
I have always had a smell coming from my duet washer. I put bleach in and run it through a rinse cycle, but it always comes back
there may be some dirt or other things collecting in the drain boot attatch to the drain pump there is usually a plastic coin trap located inside the rubber boot his will cause a musty smell in the washer.as well as a moldy door boot seal.if the door boot is moldy it needs to be replaced.
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Thanks for your suggestion about looking in the lip of the seal. I found one of my three year old granddaughters socks. Also, the seal for very dirty so I mixed a 50% solution and 50% solution of chlorox and used an old towel rag to wipe and wash throughly around the lip seal.
I noted that the aluminum ring inside the washer had also accumulated a lot of dirt. With one hand and fingers I held the wet cholorx towel inside the ring and with the other hand spun the tub around several turns until I had removed all the dirt and grime.
It did have a moldy smell. I'll let you know if this fixed the problem.
dundat45
Jul 19, 2008 | Whirlpool GHW9100L Front Load Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Dec 18, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Mold? behind seal on whrilpool duet front load.
Run it a couple times on hot water with bleach in it. Should help. Also run through with dishwasher detergent in it. This helps clean too. I leave door ajar to allow air in washer. You can also purchase cleaner just for this at parts place.
Nov 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
