Question about Hitachi 43FDX01B TV
Blue line convergence not working - Hitachi 43FDX01B TV
  • Hitachi Master
  • 3,459 Answers
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Projection <a rel='nofollow' href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">TV</a> sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look <a rel='nofollow' href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">3D</a>, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. <br /><br />This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. <br /><br /><b>Common Symptoms include....</b><br /> <ul class="h_mi"> <li class="h_mi">Screen looks 3D <li class="h_mi">Colors don't line up <li class="h_mi">One or more colors can't be adjusted when using the convergence menu. <li class="h_mi">Screen is bowed or warped. <li class="h_mi">TV shuts off after powering on. Power light will blink. TV may also make a chirping noise. </li></ul>Here are some <a rel='nofollow' href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull#" target="_blank">photos</a> of convergence problems.<br /><br /><img class="h_mi" src="/uploads/images/42D3683.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/7859B01.jpg" /><br /><br /><img class="h_mi" src="/uploads/images/E87380C.jpg" /><br /><b>Here is a quick tes</b><b>t....</b><br /><br />Using your original remote go-to the settings menu then goto the convergence section.<br /><br />Try to adjust the red and then the blue convergence.<br /><br />You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight. <br /><br />If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem. <br /><br />Note: If you TV has as flash <a rel='nofollow' href="http://www.fixya.com/#" target="_blank">focus</a> or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix<br /><br /><b><img class="h_mi" src="/uploads/images/69189A5.png" />CONVERGENCE SOLUTION<br /><br /></b>You can see some more examples and find a fix using this link on Fixya <a rel='nofollow' href="http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull" target="_blank">http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull</a></span>
Posted on Aug 28, 2010
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
Convergence Adjust
It means probably one of the two convergence ICs has blown
Jul 13, 2008 | Hitachi 53FDX01B 53" Rear Projection...
The blue lines on the left lower side of the tv will not converge. The tv has never given me a problem. I woke up one morning and powered it on and noticed the blue is misaligned. I tried converging and...
This problems can happen to the DLP tv any times of it tv life.Tv is 100% have a convergence problems.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
Blue gun adjustment does not move blue line in menu convergence function. Any way to adjust or fix?
No.Fix.Tv have dead parts on the tv convergence board.Tv colors lines R,G,B mis alignment,can't move any colors lines.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead on the tv convergence board.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Toshiba 61H70 61" Rear Projection...
I can set convergence lines on red and blue lines. the
Replace both of your convergence ICs they are big black ICs will have STK392-110 on them Call Mats 1-800-628-1118 10.95 each.
Jan 09, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Blue lines on the screen
Remove Convergence / power supply circuit board...replace
convergence IC's with first quality ....either Philips,Toshiba or
best choice = upgrade to Hitachi = CZ 01341....let me know
if you have ? 's............T.
Feb 12, 2008 | Televison & Video
Ghost blue cant line up convergence 2lines and blue t on the left of what suppose to be white t
Your Convergence ICs need to be replaced. If you need anything further let me know.
Jan 23, 2008 | Zenith R40W46 40" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Hitachi 43FDX01B TV Logo
136 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
