Question about HP Photosmart C4180 All-In-One InkJet Printer
Start up/shutting down
Printer green button says "shutting down" but it will not start or shut down!
Pulled all the plugs out of the printer, replaced them, bingo!
Posted on May 07, 2008
Blinking green light
Try disconnecting the computer from the printer and shutting it down by removing the power cord and then also shut down the computer for a minute or so and then reboot it and check in "Printers" and see if it has anything waiting to be printed and if so clear out the queue. Flashing green light indicates that the printer is receiving data from the computer and/or printing so you shut it all down and cold reboot to clear out the computer confusion in both the computer and the printer.
Sep 19, 2014 | Brother HL Office Equipment & Supplies
Prints multiple copies of job and will not shut off or stop printing
Unplug the power cord from the printer. Hold down the red "X" button. Plug the power cord back in while holding down this button. Release the button. Should see flashing red and green lights. Unplug the power cord again. Replug. Should be reset.
Apr 10, 2011 | Dell 1100 Laser Printer
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Won't switch off
Having taken the printer apart to check all connections, etc, I put it all back together but the problem persisted. I eventually solved it by holding down the On/Resume button and then plugging in the power lead. The printer started, I was able to shut it down normally, remove the power lead, then start it up again in the usual way ie. without having to hold down the On/Resume button before plugging in the power lead. I can only assume that some sort of "glitch" occurred when it was originally turned off.
Feb 06, 2010 | HP PSC 1350 All-In-One Thermal Printer
Ip 2000 on button flashes green then orange ,
Needs resetting at best.....perhaps it might shut down completely.....I had the same problem then my printer completely shut down!
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Keeps blinking. I've shut it off, and cancelled all print jobs - even unplugged it. Keeps blinking. Says there is an operator error
Try this:
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
If this not help may the print head is defective.
Oct 07, 2009 | Canon BubbleJet i560 InkJet Printer
I can't get my HP officejet 6310 All-in-One to turn off
This model takes an extremely long time to shut down.
I have had mine on for 2 years. because it takes way too long to start up and shut down. Still works fine.
If you really really want to power this unit down.
Purchase a strip plug with power buttons for Monitor, CPU, Printer and Device 1 and 2. Shut down the PC normally then hit the Printer button on the strip plug. Viola printer off no worries.
Oct 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
Aug 25, 2009 | HP Photosmart C6100 All-In-One Printer
Prints 1st page ok, down hill from there
I would try a cold reset. Turn the printer off; hold down the green "GO" button, continue to hold while you power the printer "ON". Hold the green "GO" button until the printer shows al " ********** " across the screen; now let go. It should soon say " Restoring Factory Settings ".
Aug 10, 2008 | HP Color LaserJet 3500 Printer
HP Photosmart C4180 All-In-One InkJet Printer Logo
147 people viewed this question
Ben Johnson
