Question about Eljer Toilet Onepiece Canterbury 081162047
How to replace the flaper unit . the tank does not come off
    Problem Solver:
  • 5 Answers
Call Eljer or go online to look at their trouble shooting guide.
Posted on Aug 27, 2010
Flaper closes inmaturly after flush
I had that happen due to water level on being high enough in tank. I increased my tank water and problem stopped for me. I also adjusted the flapper chain that also helped. I also replaced the flapper and it was also worn out.
Feb 25, 2013 | Kohler Home
We have an imagerunner c2620 the fixing unit went bad and we just replaced it. Now it says there is a paper jam in that area and there isnt any paper where indicated
Did you replace worned out unit with new one?
If Yes, check the connectors of sensors and connectors from fixing unit to copier.
Did you remove all protective sheets from new fixing unit? Check that nothing is in paper path way or that sensor flapers arent broken.
Leave an email, and I can send you the service manual.
Sep 17, 2011 | Canon imageRUNNER C2620 Color Copier
I have a cannon Ir2000 if i switch it on, it says "check printer cover" Which printer cover is it talking about?
probably the problem is in left lower door, beneath the bypass unit. Open the cover and strongly close it!
Worst case scenario is broken paper flaper, but for this call service...
Aug 16, 2011 | Canon Office Equipment & Supplies
I have a american standard cadet 111 6liter elongated toilet. I have replaced the flaper and the rubber seal in tank and I still have a problem with the toilet refilling itself after a hour or so. Any...
To see where the water is going, place some red cake dye in the tank and see where the water turns red....this will show you exactly what is happening and where the water is going...
heatman101
Feb 22, 2011 | American Standard Cadet 3 Right Height...
Replaced the seals because it was running. Water is still leaking from the tank somewhere so it keeps refilling....it's constantly leaking and refilling. how can I repair this.
You say you have replaced seals. I assume that you are refering to the flaper valve that controls dumping water from tank to bowl to flush. To make sure you have a good seal put a dozen or so drops of food coloring directly into tank when it's full and observe for a hour or so to see if water in bowl is discoloring. If it is then you are still leaking there. You can shut off water supply off or flush toilet and manually hold flush valve closed. Check to see if there are any rough spots on flapper seal that could stop flapper from sealing good. If you find rough spot then make sure the surface is dry and sand lightly with medium grit sandpaper.120 grit or finer.
One other thing to check is if your toilet has the plastic or rubber tube that goes from the flush valve into the overflow. Make sure that this tube does not set below water level in tank when it is full as this can create a suction or syphon,
Hope this helps you. Thanks
Jan 10, 2011 | American Standard Home
The proplem was ,( Open left drwr. cover ) , and we oened the drwr. cover but the peoblem stell flashing
do you have two drawers?
On second drawer there can be problems with pick up clutch, but... first thing first.
When you open the drawer cover, you will see one plastic vertical guide for paper, when you press it it lifts up the paper sensor flaper.The flaper must be in the midlle position of slot on these plastic quide.If it's not apply some wd 40 on edges of guide and on the flaper and left edge of the flaper.
Manualy push the guide and while holding it close the door.
Hope that helps!
If not keep me posted, with details.
Sep 18, 2010 | Canon iR 2016i Black and White Copier
Tank will not fill up after flush. i hear water
Fill valve in tank has a washer in it you take it off and make sure there is no trash restrcting flow and also chack out flaper to see if it is sealing correctly.
May 03, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
I fixed (I think) a broken flaper valve assembly. In doing so, I created a leak where the bolts affix the tank to the bowl. I can't find a rubber gasket assembly (I don't even know if that is the right...
Go to home depot and tell them you need a tank-to-bowl gasket. They have them at home depot and it may come with new bolts for the tank-to-bowl fastening. New bolts would be a good idea to pick up anyway. One rubber washer under each head, then a rubber washer at the bottom of the tank. Use a metal washer and nut to secure this to the tank, then use another washer and nut from the bowl to the tank.
Jul 06, 2009 | Sterling Home
ImageRunner 2020 paper tray open warning - cannot fix
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Apr 08, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
117 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
