Question about Frigidaire Dishwashers
Water has not drained completely away. Scummy residue left behind. Now machine won't respond to 'light wash' command. It's a free standing Ultraquiet 111. I don't know how to clean it. Help...please
  • hrcuff Aug 26, 2010
    thank you. I have mopped out the very small amount of water remaining.
    However, machine not responding to command. No lights, nothing. I've checked plug and circuit breaker, both OK. To do anything re. your suggestion is beyond me ( old widow)
    Do I ask an electrician or a plumber..........when do I give up and get new appliance?
  • hrcuff Aug 28, 2010
    thank you silver dragon. Sadly the DIY is not an option...but appreciate the help. Now I must find a hands on expert and your diagram will be useful.
    cheers
  • Frigidaire Master
  • 12,061 Answers
Hi, well the ONLY reason that a machine will NOT drain away, is either the Pump, is faulty, there is a blockage in the outlet Pipe, or a blockage in the internal pipes. You will have to either DIY or call a professional.
If you DO wish to DIY I include an exploded diagram so you can see how it all goes together and what hoses are where. You gain access via the Inspection panel
Below is your service manual, for your series.
http://appliancejunk.com/forums/index.php?topic=2936.0
Posted on Aug 27, 2010
  • Frigidaire Master
  • 3,247 Answers
You will have to empty the dishwasher before you can do anything further. Use a small container and empty whatever you can and then use towels to scrub out the rest.
The problem you may be having is that of a back flow from the kitchen sink. The likely cause is a blocked kitchen drain or if you use an insinkerator then it may be full.
Please post a comment confirming my observation above then we can proceed to next stage. Also note down which lights if any are lit up on the panel when you press light wash. When you say does not respond - I am assuming nothing turns on in the dishwasher.
Posted on Aug 26, 2010
  • Sam Aug 28, 2010
    Sorry to hear that you have had no luck with your dishwasher.
    If you say there is nothing happening when you press the buttons - and the lights are all off then you have a possibly a complex problem inside the dishwasher.
    A new dishwasher will set you back atleast $600 - so you will have to check this against getting a technician to have a look - most likely the controller power is gone and this is usually linked to a thermal fuse blowing up. The thermal fuse protects the dishwasher from overheating. Overheating can occur if the heater is faulty or the thermostat that checks the heater temperature is faulty.
    Whatever it is will require some testing and parts replacement.
    Not an easy choice. Sorry cannot help much unless you are able to test a few things by opening the dishwasher.
    Let me know if you still want further help form me on this.
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
Water not drainiNg after completion of cycle
Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. This should solve the draining issue.
As for the dishes not being cleaned on the top drawer check the holes on the top spray arm. If the holes are blocked up with food you will get poor wash results. Best way to clean the spray arm is to remove it by unscrewing it and giving it a good clean under the tap and poking the holes to clear any blockages.
Hope this helps
May 02, 2010 | Westinghouse 24 in. MDP531 RF...
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
MACHINE WILL NOT DRAIN COMPLETELY THEREFORE IT SMELLS
No washing machine drains completely , there is always residual water in the hoses and heater sump
If the machine smells do a couple of hot washes with no clothes in but add a good dose of soda crystals dissolved in hot water.
Pour this mix into the drum before you start the wash
Try going back to old fashioned soap powders for a few washes , these contain some bleach and soda which kill of the fats left inside your machine by the normal 40 & 60 degree washes
Jun 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
