Question about Cutler Hammer Eaton Electical #BD3030 Breaker
I have a bedroom-office that is on a 15 amp breaker. This is also the room where my ham radio equipment is located. When I key my radio with the amplifier on, the amp draws about 10 amps, the lamp on the desk goes a little dim. Can the 15 amp breaker be replaced with a 20 or 30 amp circuit breaker and solve this problem? It's not bad, just a little annoying. Thanks.
  • 395 Answers
A Higher rated Circuit breaker will not solve the problem if is not tripping now and putting in a higher rated breaker could lead to the point where the wiring itself is overloaded without the breaker tripping.
From your description, I think the problem lies where the wiring is attached to the back of the wall outlet. It may have been installed improperly and over time a resistive connection has developed, getting worse as time goes on and caused a noticeable voltage drop, as well as getting hot, when a decent current is being drawn. With the breaker off remove the wall outlet and any evidence of over heating should be readily visible. Cleaning and reterminating should solve the problem. If the connection at the wall outlet is OK, then a similar problem could have occurred where the wiring is attached at any other wall outlets in the same circuit or at the circuit breaker end of the circuit.
Posted on Aug 27, 2010
  • 2,019 Answers
The breaker does not limit the current until it gets to the point it trips totally.
So the breaker is not involved.
The problem is not the wall outlet because then the lamp would always be dim, not just when you power up the transmitter.
The problem has to be that the wire from the breaker box to the bedroom/office has to be too small. It must be 14 gauge, and have a run long enough for the resistance to build up. If it is 14 gauge, then you should really have a 10 amp breaker instead of a 15. If it does not trip, switching to a smaller breaker will not make any difference in normal use, but will be essential in case of an overload that could start a fire.
So unfortunately what I suggest is running another circuit.
A 10 amp tube radio is very similar to running a microwave oven, and should really have its own dedicated line. I would recommend 12 gauge wire with a 15 amp breaker.
This is not hard to do, and depending on the local building codes, you may be allowed to do it yourself. Ask and we can explain the details, if you are interested.
Were do i sell a bunch of ham radio equipment
Ham radio fests, Craigs list, local ham club. Maybe a CERT type of group (citizens emergency response team). We have those and they use ham radios. Also try emergency services in your county. You will never get what you paid....Used Ham gear goes cheap.
Oct 21, 2015 | Radio Communications
No power in back bedroom
Locate your circuit panel, and check your fuses/circuit breakers.
Maybe breaker tripped?
To reset, remember: All the way to OFF position first, then flip towards ON.
Jun 09, 2015 | Televison & Video
I have a Teaberry stalker one 40 channel. Is it rare because most of the stalker one's I've seen are 23 channels.
if you are looking for 40 channel CB than i would look under ham radio operators, CB repair shops, if you are looking for another one, you may even look up on www.ebay.com
the ham radio operators would be where i would look and talk to.
i would look for ham radio clubs, they have swap meets all the time, old tv and radio repair shop. i have been in ham radio operations in 20 yrs and i do not know anyone. you may check out the local library., the FCC may be help you find local ham radio operator in your location. they will help you find that old equipment, than on the other side of the coin what are you willing to pay to locate an operate one is and are they willing to part with it.
good luck rod
Mar 25, 2015 | Radio Communications
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
Why would two adjacent circuit breakers in a panel trip for no apparent reason? We reset them and everything seems normal.
My first thought is that even though it's only feeding that single outlet in the room; many times the neutral wires are made together in a panel (neutral/ground bar),which tries to carry the load of the initial tripped gfci. and tripping itself. Was there a decent amount of power plugged in to either the 'dedicated' outlet or the series of outlets that go to the 2nd breaker?
Jan 24, 2013 | Electrical Supplies
Room heater caused 15 amp circuit breaker to go bad. Can we update 15 amp circuit breaker to 20 am (similar to ones next to it)
Probable not, in order for you to install a 20 amp breaker, the wiring must be a #12 gauge cable.Check the power requirement of your room heater. It should be not more than 15 amps. Check and retighten the connections to the heater.
Install a new 15 amps breaker.
Nov 21, 2011 | Electrical Supplies
I plugged a hair dryer in my room then it wouldn't come on in both rooms but all the other rooms outlets work this is the second time this month this problem has occured
Please check the circuit breaker fuses. The one in your bedroom is of lower amps. If it is 5 amps replace it with 15 amps. Also check the connections of the socket. It could be that wires there are not connected with the socket or they are burnt out thus no connection.
Dec 20, 2010 | Electrical Supplies
I have 110 voltage to all circuit breakers but no power to outlets in 2 bedrooms .
Check at the output side of the breakers with a voltmeter. Make sure that a white neutral wire didn't get hooked to a breaker. You may need to pull the outlets in the bedrooms to see if they are wired correctly. Good luck!
Sep 25, 2010 | Federal Industries 15 Amp Federal Pacific...
Blown breaker
It sound like all of those go through your bathroom GFCI. I would recommend moving your outdoor circuit breaker indoors if possible or enclosing it to make it water-proof. You may also do some rewiring from your main breaker box ( if you are handy) to eliminate the outdoor box completely considering you have 100 amp / 200 amp breaker box inside your house. If you still have an old FUSE BOX with 60 amp service, I would recommend replacing it with a 100 amp or 200 amp breaker box depending on the size of your house. I would separate the laundry room by itself with 12/2 gauge wire with ground on a 20 amp breaker. You can then take your bathroom (using 12/2 gauge wire with ground keeping your gfci ) and run it to another breaker in the house with a 20 amp breaker or add a new one if there is room in your main box. Now all you have left is the porch light. You can run that separate from everything to your main breaker box using 14/2 gauge with ground to a breaker in your main box by adding a new 15 amp breaker or adding it to another 15 amp breaker that does not have a very high load such as a bedroom. In general Kitchens, Bathrooms, Laundry rooms should be on there own separate 20 amp breakers. Most every other room can be 14/2 with ground on a 15 amp breaker... hope this helps....Joe
Dec 17, 2008 | Prime 10 Amp Circuit Breaker
Cutler Hammer Eaton Electical #BD3030 Breaker Logo
90 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
