Question about Samsung LN-T3253H 32 in. LCD Television
I have a samsung lnt3253h lcd tv can you tell me the rating for the pico fuse on the t-con board and/or the part # for the t-con board assembly
  • 10,594 Answers
Both chip fuses are 125mA 60V
This tv has two type of T-con boards, Click Type-1 and Type-2 to recognize what kind of t-con in your tv.
Thanks.
Posted on Aug 26, 2010
  • mickd0717 Aug 26, 2010
    thanks jee, i'll have to double check my type. would this be a good place to start if I have audio but no picture on my set
  • Shahid Electronics
    Shahid Electronics Aug 27, 2010
    Yes, t-con could be reason of no picture problem if back light is working.
Samsung LCD model #LN32A330JIDXZA has a very bright color, can hardly see the picture
My problem began the same way, then the tv turned off everytime I tried to turn it on. First I opened the tv, made a list of all the electrolithyc caps values and temps in the power board and gone to the store and bought all except the bigger one (like USD 8) changed all the caps and then the tv didnt turn off again but image was all white.
Then searching in youtube found about the t-con board issues but the entire card was too expensive to dump so searched how to repair the t-con and found I can change the main chip so bought 2 in ebay from china took like one month but was just USD 8, so carefully cut all the old chip legs, retired the chip, used a soldering iron to retire the old legs, cleaned, put bits of new solder in the tracks, placed the new chip and began to paste leg by leg, tested continuity and checked for solder bridges between legs, assembled, turned on the tv and half screen has strips bot the left side was ok so rechecked flex cables between t-con and lcd and found bent tracks, carefully repositiones, assembled and now my mom has a brand new samsung 32in LCD to watch CSI and stuff... Sooo F_ck u Samsung LOL
Hope you can repair yours, every problem is a world so may not work for you but for USD 8 in chips, patience and some pulse soldering i think it worth the try.
Mar 27, 2013 | Samsung LN32A330 32 in. LCD TV
T-Con Board for Samsung TV
Here's a place where you can purchase a T-Con board. TV Parts Universal TV Stands DLP Chips ShopJimmy
May 04, 2017 | Televison & Video
I have Samsung UN55B7100 LCD TV that have a double picture with 5 horizontal lines in the top of the screen. We got a tech from Graigslist and he changed the T-con but the problem still exisit. Anyone...
Tech from Craigslist? Does he know if the repalcement T-CON (more likely to be used board) is good?
Learn more on how to tell if it is the T-CON or LCD panel is causing the problem.
T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download.
Did he also check the DC output voltages feeding the T-CON board?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
Jun 10, 2011 | Samsung UN55B7100 TV
I have a Samsung Syncmaster 930bf monitor, when I turn it on, I can see only white. Backlight is working but there is no picture. I tried both video inputs, no difference. Capacitors on power supply part...
It sounds like the ribbon vable between the logic board and the T-CON board on the LCD panel may have come off or it has blown fuse on the T-CON board, or not getting the 5Vdc from the LOgic board to the T-CON board due to bad 5vdc switched transistor that supply the voltage to the T-CON board.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung SyncMaster 930BF 19" LCD Monitor
We are having SAMSUNG LA37R81B tv at home its showin blurred picture we asked repair man he said we need the tcon board number so that we can buy we now need your help
it possible that the problem is the the TCON board, you can try websites Shopjimmy.com,Ebay.com to buy a refurbish board for the replacement.
Also note that
The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
Hope this helpout..
Jul 30, 2010 | Samsung Televison & Video
The l950t tv is power on and the screen is white totaly. Audio ok and channel change is ok
Check the connection between the logic board and the T-CON board on the LCD panel assembly, check the fuse on the T-CON board for 5vdc on the fuse of the T-CON board.
Look at LCD panel album to see what T-CON board looks like.
http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jul 27, 2010 | Daewoo Lucoms L950T 19 inch LCD Monitor
T-con board for your samsung
The t-con board is very easy to replace. The only problem is you need to take a bunch of stuff off before you can get to it. How to replace it:
1. Take off the back of the TV
2. Unplug all the wires connected to the middle boards, you will need to take off the whole assembly that the 2 boards are attached to, the main power board and audio/video board.
3. The t-con board is under the shiny metal cover near the top of the TV. There are four small screws holding the cover in place. (You should be able to see the cover when you take off the back plastic cover of the TV).
4. There are 3 connectors attached to the board. The white one that comes from the audio/video board and 2 small ribbon type that connect to the front of the TV, probably the LCD panel.
5. The 1 separate connector is self explanatory. The other 2 are a little more difficult. They just slide into place. When you look at the connection, there is a brown "flap" holding the ribbon in place. You need to flip it up from the top side of the TV.
6. The old t-con board just comes out and the new one goes in.
Hope this helps!
Let me know if you have any other questions.
Ben
Sep 16, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Pico fuse
It's on the T-con board itself at location Cp1 which you will find printed on the board itself.. The fuse is a tiny s/m (surface mount fuse but you can use a pico fuse of same value. According to schematics it's a 1.5a fuse. Simply solder one across the s/m fuse and if it opens then change the board. Samsung p/n# Bn81-01286a
To test the fuse use a VU meter set to continuity.
Pico fuses are readily available at almost any electronics supply outlet. I get mine from ACME Sales in Florida (least expensive) but even your local Radio Shack might sell them...
Bill
Sep 04, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LNS 4692 lcd tv t-con board
The fuse is located just upper right to the connector that attaches to the main board. This is a SMD pico fuse that is rated for 3 A @ 32 V DC that protects the Vin bus. Replacing the fuse may not fix the problem as it has most probably opened because of failure of another component.
Jul 26, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-T3253H 32 in. LCD Television Logo
294 people viewed this question
Henry  Thomas
Henry Thomas
