Question about Logitech QuickCam Chat Personal Web Camera
Logitech Quickcam Chat - no sound recording!
I just got a webcam for my birthday a couple weeks ago (April 20th, 2008, to be exact). It's a Logitech Quickcam Chat (2006 model, according to the box).
Now, I installed it, had it all set up...and while the video recording seems to work fine, the camera doesn't seem to be picking up any audio whatsoever; even the bundled-in headset doesn't seem to work with it. Any ideas on how to solve this?
If this helps; after checking Device Manager, the webcam is nowhere to be seen under "Sound, video and game controllers" and only shows itself under "Imaging devices".
  • 2 more comments
  • Mallic May 07, 2008
    I did everything you mentioned. Under the Volume Controls, I indeed had to check the boxes to activate Stereo Mix, Mono Mix, Aux, and SPDIF. Everything was maxed and nothing was muted.
    However, when I came to the Adjust Audio Settings step, under both the Audio and Voice tabs, the only recording device listed (for both "Voice recording" and "Sound recording") is "NVIDIA(R) nForce(TM) audio". My tests after this were just as unresponsive as I've found them to be before trying your proposed solution; no trace of audio picked up at all.
  • Mallic May 08, 2008
    I have tried all of this and have had no success with this particular webcam. Fortunately, after checking Logitech's warranty, it appears that I am still within the 30-day guarantee, and so...I can just get a refund or another webcam (maybe another Quickcam Chat or some other camera of equal value).
    Your prompt and detailed assistance was much appreciated, though, and for that, I thank you.
  • Mallic Jun 18, 2008
    ...umm...I did...
    Oh...it didn't go through the first time...well, thanks!
    President:
  • 2,712 Answers
At the bottom right of your screen, you should see an icon for volume. Right click and select Open Volume Controls. Click Options > Properties > recording and make sure all the boxes are checked. Click OK and make sure all levels are maximum and nothing is muted.
Next, right click the volume icon again, and select Adjust Audio Properties. Go to Audio tab and then Voice tab and select the appropriate recording device from the drop down menu.
By the way, your camera will only show up under Imaging Devices in the Device Manager and not under Sounds,Vidoe and Game controllers.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
  • Swilin Sampson
    Swilin Sampson May 07, 2008
    Ok, try a clean install as outlined in my article HERE.
    SHOULD THAT NOT WORK, ITS MOST LIKELY THERE IS A DEFECT WITH YOUR CAM AND YOU WILL HAVE TO GET IT REPLACED.
    See here about getting an RMA.
  • Swilin Sampson
    Swilin Sampson Jun 15, 2008
    Kindly close this thread with a Fixya rating if you have been able to fix the problem, so that I can remove it from my work queue.
    Thank you.
Need software for my Logitech QuickCam.
Not sure the exact model wish i could give you the direct software but i will take you close to it...
http://www.logitech.com/support-downloads
just click the link and put your model in and download away...
Aug 16, 2010 | Logitech Quickcam Chat Webcam
I lost my installation cd for Logitech Quickcam Chat
you can get the software in logitech.com try that once.
May 27, 2010 | Logitech QuickCam Chat Personal Web Camera
Logitech Quickcam Chat No Audio When Recording Video
WHEN UR MESSENGER IS OPEN.........CLICK ON TOOLS AND THEN AUDIO/VIDEO SET UP....SEE IF THAT HELPS
Apr 16, 2009 | Logitech Quickcam Chat Webcam
Viewing pictures
Search in windows for Logitech Quickcam and open the folder displayed. There should be a webcam manager in the folder. The pictures will be saved there.
Mar 13, 2009 | Logitech Quickcam Chat Webcam
Ncan't hear or be heard
ican not hear them, i dont know where is the problem.
Oct 20, 2008 | Logitech Quickcam Chat Webcam
Cant record video-- keep getting error code
Never mind--- Just needed to restart the computer-- works fine now!
Sep 29, 2008 | Logitech Quickcam Chat Webcam
Quickcam chat has no sound
my webcam conceptronic is NOT working
I have fedora 7 witch skype 2.0 beta
what i can do?
mi camara web conceptronic NO esta funcionando
tengo fedora 7 con el skype 2.0 beta
que puedo hacer?
Feb 13, 2008 | Logitech Quickcam Chat Webcam
Logitech Quickcam Chat - No audio
Try testing it, last time I checked skype has a test section, its hard to find, but its there. You just talk into the mic and skype records it. Then play back.
It is possible the mic isn't working.
Before you consider taking it back, make sure you follow the instructions to the letter.
Dec 25, 2007 | Logitech Quickcam Chat Webcam
Logitech QuickCam Chat Personal Web Camera Logo
387 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
