Question about Kitchen Ranges
How do i change hinge on stoves 600g door as door has dropped and wont shut properly
2 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Posted on Feb 26, 2008
The door on my rangemaster 101 wont shut properly
John, it sounds like the problem is in the hinges. They are not aligned, even thought the seal has been changed, the door is not seated properly as a result the steam comes out. You will need to readjust the hinges. If this seems out of your comfort zone you may want to call a professional.
Jan 09, 2015 | Rangemaster Kitchen Ranges
Why doesn't my oven door shut properly
What brand is this oven? I'll make a guess it is a Jenn-Air, because that brand has a weakness with the oven door hinges and receptors (receptacles), and they need to be replaced.
Aug 31, 2014 | Kitchen Ranges
How do I know if the hinge is broken on the stove door?
the door will fall off when opened if both hinges are broken, if only one hinge is broken the door will drop down on one side.
Apr 20, 2012 | Brown Stove Works Ovens
The bottom oven door does not completely shutThere is a gap from which heat escapes.The door shuts but then drops open a very little way when pressure is relinquished
When the door is open, you will see some small cross head screws near where the hinges go into the door. These should be tight. If they are, then it could be the hinge failing. Try espares for a new set of hinges, but be warned you will have to take the entire oven out of its housing and both side panels off to get the the hinges.
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Eurogas oven door
If it is a drop down door, then generally speaking it is the door hinges nthat need replacing, as they are mot usually adjustable.
Hope this helps.
Jan 06, 2010 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
May 26, 2009 | Ovens
We own a Eurogas 900mm stainless steel freestanding stove which we purchased in 1998. The oven door hinges need to be replaced but we are unable to find a local supplier. We believe the stove was...
I have the same stove but do not have a problem with the oven door hinges but rather the glass cooker hood hinges--although my knobs are starting to burn. Both hinges have popped in separate occasions and both times I have called the Cape Town agent foo Eurogas and had fantastic responses from them. http://www.eurafrican.co.za/contactus.html
Aug 05, 2008 | Kitchen Ranges
Main oven door does not shut properly
i removed the side panels which exposed the hinge mechanism. I have then removed the whole door and the associated hinges by simply unclipping the retaining springs.
Dismantling has revealed that the pivot pins have become dislodged from their housing, and this is why the door was not shutting properly. I am now spot welding the pins back into position.
Also noted is wear in the slots in which the pins rotate but am hoping that it is all still serviceable as I think spares for Stoves are expensive.
One other point to note is the very poor design of the whole hinge assembly. Not what I expected from Stoves.
Jul 31, 2008 | Stoves 720EF Electric Double Oven
Stove handle/door
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
