Question about Compaq Presario 2100U Notebook
Presario 2100 hi. just purchased a 2100. i bought it faulty. the seller says sometimes it boots and others its dead. now i know it suffers from compaq power connector wobble. but all i can get it to do is on pressing the power button i get three blue leds ligh on constantly the fan tries to run for a short while the hd the same then it shuts down. also i get orange speaker light. and one blue light on the front to the right. im suspecting processor? and ideas as im unemployed and would like to fix myself. thanks dave.
1. Remove the battery.
2. Check the power supply connector to make sure that the two prongs at the end are on either side of the pin, as you may not have enough power to fire the machine.
Posted on Nov 12, 2008
Full format of compaq presario 2100
Most notebooks have a separate partition on the hard drive that holds the recovery media needed to restore the unit.
You can usually run this by pressing F10 during the boot up process. You may need to press it several times in order to get it work.
If that doesn't work, then you will need to contact Compaq in order to order the recovery media kit.
May 09, 2010 | Compaq Presario Notebook
Compaq presario 2100 how to install a Wireless pci card
If there is no antenna then you'll have to buy the wire set via eBay, take apart the lcd, remove the top assembly of the laptop and then run them through the computer and put everything back. NOT FUN.
It's probably much easier and realistic to just purchase a usb wireless card.
Hope this info helps.
Let me know if you have any other questions.
Best of luck!
Nov 28, 2009 | Computers & Internet
Compaq presario 2100 laptop operating system not
On my Compaq Presario Windows 7 laptop, I have got "Operating System not found" error, to fix problem,Windows Boot Genius helped me finally!
Oct 10, 2009 | Compaq Presario 1692 Notebook
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
Argon PXE Boot Agent v2.01 2002 - PXE - E61
Your computer tries to "boot" from several devices:
* floppy-disk
* disk-drive
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Jun 03, 2009 | Compaq Presario 2100 Series: 1170B01-90...
I can't find and install driver modem for compac presario 2100
Here is the link to download your modem driver.
HP Compaq Presario 2100
Mar 12, 2009 | HP Compaq Presario 2100 Laptop
Screen or computer problem?
Is it a laptop? conenct it to a monitor, see if that works, then u know it might be the LCD.
Mar 06, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
Compaq Presario 2100U Notebook Logo
105 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
