Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
I have a Sears Model 596.68952801 frig with the freezer not freezing. Can you help me fix it?
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Aug 26, 2010
What year was model number 253. 54622402 built? Freezer is not getting cold enough is it worth fixing?
can;t help with sears model # for age but do ck the model # plate for the type of coolent like R 12 or R 134 / if its 12 i would replace frig .. the poor cooling on any frig may be caused by dirty coils or fan motor blowing over the coils . clean them and ck that fan is going . ther is also a fan in freezer that may have quit so ck that one also . mm hope this helps .. feeed back pls .. mm
Sep 18, 2011 | Kenmore Side by Side Refrigerator
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Amana refrigerator not cold
The fan that should circulate air between the two compartments has failed. These usually have 'sleeve' bearings which can become sticky and fail to start up without help. Go to the Sears/parts website and enter your Amana model number; if you are lucky, they will have a line drawing of your model which can aid in finding how to access the fan:
Sears Parts Dept.
They have info for thousands of non-Sears items and most can be ordered via that website as well.
Feb 25, 2010 | Amana ABB1927DE Bottom Freezer...
Frig is not getting cold at all and the freezer is not freezing Thanks
Hi, I can help you. What brand & model# is this? Is there any frost built up on the inside rear freezer wall
Vic
May 27, 2009 | Freezers
Kennmore is freezing everything in the fridge side and it is turned down to 0
YOU HAVE A BAD FRIG. THERMOSTAT REPLACE IT,GO TO SEARS .COM CLICK ON PARTS ,PUT IN YOUR MODEL NUMBER(ON INSIDE OF FRIG. OR FREEZER WALL) AND YOU CAN GET THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Oct 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
My freezer is too cold, now frig part is way too warm, we unplug it, defrost the freezer, then it's ok for a week, then it freezes up again, so on......... help....... thank you! =)
YOUR DEFROST HEATER IN THE FREEZER IS BAD,YOU CAN REMOVE BACK PANEL TO GET TO IT,YOU NEED A VOLT METER TO CHECK IT,IF IT'S TO MUCH FOR YOU CALL A LOCAL HONEST APPLIANE REPAIR GUY PS DON'T CALL SEARS THEY COST A FORTUNE-MIKE
Jun 03, 2008 | Frigidaire Refrigerators
Freezer cold refrig warm
4 yr old sears side by side...not cold in freeze or frig side
May 21, 2008 | Frigidaire FRS26ZSG
Need Help - Galazy Refrig. 18 cu ft
you can pop that model number in at their site sears.com.(look for parts section on there homepage. you see complete exploded views of your refrig pick out what you need rightt here
Mar 22, 2008 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
