Question about Xerox WorkCentre M118 Black and White Copier
Getting Scan to email to work on the Xerox workcentre M118? We use a go daddy webmail for work and we are trying to get the scan to email to send the emails to us?
  • jastillwell0 Aug 27, 2010
    We have done that. We created an account using hmailserver and what I think the problem is that the printer and the server are not communicating correctly. How can I get these two to communicate correctly using hmailserver?
  • 3 Answers
You have just to active "send email" protocol, reboot machine and put ip adress of smtp server on the correct location in machine user interface and if your webmail need authentification you should create an account in your server and put them under smtp server on machine user interface.
good luck
Posted on Aug 27, 2010
    You are going to have to be more specific please? I feel like I have done anything and everythig possible and I cannot get this to work.
I need Xerox workcentre M18 Drivers
Xerox WorkCentre M118 Drivers
The required drivers can be downloaded from the above link from Xerox Official Support. Select the operating system you have on your PC and download / instal the files.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Xerox WorkCentre M118 Printer
WorkCenter M118 it stop sending scan over email. Insted of sending it print the NDR with error E11202
Solution : Make Sure the SMTP (Mail) Server is an Open Relay Server or Uses POP-Before-SMTP Authentication The mail server being used must be an Open Relay server or use POP before SMTP authentication. If the mail server being used requires SMTP authentication, the scan to e-mail process will fail. The WorkCentre is unable to access the mail server when SMTP authentication is required. Contact your Internet Service Provider (ISP) or System Administrator for additional information.
NOTE: The WorkCentre was designed to send e-mail through internal corporate mail servers. In most cases, if using your Internet Service Provider (ISP) mail server, the scan to e-mail process will fail because most ISP mail servers require SMTP authentication to send mail. Contact your ISP for additional information.
Feb 24, 2011 | Xerox WorkCentre M118 Black and White...
Cómo cambiar el fusor de la xerox m118 y
I need a card red to be used in the Xerox M118 with connection RJ45, wich I can get, model or any specificacion
Jan 20, 2011 | Xerox WorkCentre M118 Laser Printer
I have Xerox WorkCentre 5230A when i am scanning it is give me this error code 018-591
According to the manual, 018-591 means:
"The number of suffixes attached to folder or file names exceeded the limit.
Change the names of existing folders or files, or move the folders or files into
another folder."
good luck
Nov 29, 2010 | Xerox WorkCentre M118 Black and White...
Xerox workcentre M118 is having problem in pulling the paper to the fused roll.. what could be the problem?
Most likely one of the rollers in the paper path between the developer and the fuser is slipping. You are going to have to get a Xerox tech to take a look at it.
Sep 10, 2009 | Xerox WorkCentre M118 Black and White...
Paper Tray won't read
That is a paper tray issue with that machine.
The tabs that are supposed to actuate the switches on the back of the tray either twist or get out of position.
You can try sliding the paper guides around, but more than likely the tray will need to be replaced.
Common problem on the 118
Jan 19, 2009 | Xerox WorkCentre M118 Black and White...
CHANGE A m118 TONER
hey follow the instructions on the toner box,pliz follow them,if u fail get back here.
Sep 18, 2008 | Xerox WorkCentre M118 Black and White...
Xerox Workcentre 490cx
I have the driver for window 2000 but working fine on xp. It is 5MB. Do you want it? To give me your email address I can send to you.
Apr 11, 2007 | Xerox WorkCentre 490CX All-In-One InkJet...
Xerox WorkCentre M118 Black and White Copier Logo
604 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
