Question about Sport & Outdoor - Others
I have a LMS-520 that does not activate when I depress the power button.I am getting power to the unit from the battery cable. 12.5 volts to be exact.I was referred to this site as Lowrance does not have a servicing facility
  • ghoghaug Aug 27, 2010
    The unit is a sonar GPs device as described in the user manual. I do not find any fusing from the battery to the unit just the 3 shielded cables. I know for a fact I have 12.5 volts of power to the unit , and as previously explained the unit will not activate. Where if any would I find a fuse on the LMS-520c? Thanking you in advance for your help.
    George Hoghaug
  • ghoghaug Aug 30, 2010
    ALL i GET IS A TABLE OF CONTENTS AND NO MANUAL. All I can think of doing is call it a day and get a new unit. NOT A LOWRANCE. Thank you for trying
    G.Hoghaug
    Brigadier General:
  • 3,513 Answers
You would find the servicing manual in the link bellow:
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LMS525CDF-520C_0151-461_120706.pdf
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 27, 2010
  • 3,247 Answers
I am assuming this is a Sonar and GPS device. Fixya do not have a service facility but mostly on-line facilities to guide the customers to fix it by themselves.
If this is a Sonar device then please confirm if it is the same unit as described in this user manual.
I suppose you have checked the fuse from the battery terminal to the LMS-520 is intact.
Please consult the manual and let me know which type of connection are you using.
Posted on Aug 26, 2010
LMS 520c back light not working
the light switch is in the power up button...turn the unit on let it boot up then push power button to set light as you want it do not hold down power button that will just turn unit off.. push the power button just one time if you want light brighter push till you get the back light you want
Jan 21, 2014 | Lowrance Lms 520c 5" Screen Color External...
Need new battery, of course I removed the battery some time ago to go and replace it. Yup its lost.
you lost your battery - bring a unit with you and ask for battery that fits in the store.
Dec 11, 2013 | Starrett D125 Digitape 1Inch x 25...
No power when connecting atx12V on main
did you plug in the 24 pin main of the power supply in some also take a 4 pin as well on board jim
Jul 17, 2011 | ASUS P5VDC-X Motherboard
My 636 wont start on the button, it was as if my battery was dead but i took the battery off put it on the charger and it was fully charged, what is wrong with my bike
Sounds like you might have a faulty starter solenoid.trace the positive battery cable till you find it connected to a small canister.When you press your starter this should click.To confirm this take a meter that reads volts DC and have someone press the starter,you should have at least 12 volts going into the solenoid and 12 volts coming out.It will be the larger cable. Also check the two smaller wires for power,these are the ones that send the power from the button that activate the solenoid,closing the circuit ,sending power to the starter.Hope this helps good luck
Oct 31, 2010 | 2003 kawasaki ZX-6RR
My Transducer had broke and the sonar went out, then the transducer fell completely off and the unit itself will not power up. I checked the power ot the unit and i have 12 volts going to the unit. It...
All Lowrance systems have an in-line 3 Amp fuze. My guess is that when it broke and fell off the fuze shorted out. Look back the power sypply to the unit and you will find the in-line fuze. Replsacit with a new 3 Amp fuze and you should be up and running.
Aug 30, 2010 | Lowrance LMS-332C GPS Receiver
My lms 332c comes on by itself and flashes.now i
Power switch is stuck on. It is a tricky repair, but disable the swtich internally and install one externally
May 17, 2010 | Lowrance LMS-332C GPS Receiver
Won't power up
Make sure the power is good, and the power connections are clean. Check fuses and connections. You can even get a volt meter, unplug the power cable and test for 12VDC across the two bigger female contacts on the power cable connecter. If you are getting 12VDC, then the LMS-520 is bad. If you are not getting 12VDC, then you have a bad power supply, connection, or cable.
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
1996 hd 1200 xlh blinker wont work
I'd guess I would say,next check for 12 volts at pin 7 withe left turn button depressed and you say it worked,right? No? Check flasher unit for left side.Is your speedo doing strange things to?Check alarm system.Don't know why but anti-theft feature messes with left turn signal and speedo function.Disconnect neg. wire at battery,then reconnect and reset the alarm in usual way for when it goes off.[will go off when neg is reconnected].
Feb 14, 2009 | 2003 Harley Davidson FLSTFI Fat Boy
No power supply to gearbox
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Jan 02, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
Sport & Outdoor - Others Logo
95 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
