Can not adjust the size of my screen. it pops up as OSD Lockout, and my installation CD will not play. can i get a download online?
  • 570 Answers
Don't worry please just follow the easy steps and fix your problem<br /><br />Right click anywhere on your desktop.<br /> <div style="display: none;"> <li id="jsArticleStep1"></li> <li id="jsArticleStep2"> 2 Click "Properties."<br /> </li> <li id="jsArticleStep3"> 3 Click the "Settings" tab in the window that is now on screen.<br /> </li> <li id="jsArticleStep4"> 4 Click on the marker in the "Screen Resolution" portion of the window on screen. Slide it to the left to make your desktop resolution smaller. Slide it to the right to make your desktop resolution bigger.<br /> </li> <li id="jsArticleStep5"> 5 Click "Apply" to save your changes when you've settled on a desktop resolution with which you are comfortable.<br /> </li> <div style="border: medium none ; overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none;"><br />Read more: <a style="color: rgb(0, 51, 153);" rel='nofollow' href="http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5">How to Adjust the Size of an LCD Desktop | eHow.com</a> <a style="color: rgb(0, 51, 153);" rel='nofollow' href="http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5">http://www.ehow.com/how_5925464_adjust-size-lcd-desktop.html#ixzz0xoEQrNx5</a><br /></div></div><br />Click properties<br /><br />Click the "Settings" tab in the window that is now on screen.<br /><br />Click on the marker in the "Screen Resolution" portion of the window on screen. Slide it to the left to make your desktop resolution smaller. Slide it to the right to make your desktop resolution bigger.<br /><br />Click "Apply" to save your changes when you've settled on a desktop resolution with which you are comfortable.<br /><br />Thanks .<br />Have a great day.<br /><br />
Posted on Aug 27, 2010
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
I have a w1907 HP monitor. It keeps displaying a small box in the middle of the screen that says osd lockout. I am still able to get online and use my computer normally except for this box in the middle of...
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work. To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Jan 03, 2011 | HP w1907 LCD Monitor
OSD Lockout and Volume pop up
my monitor always fading into sleep mode or some thing,on & off etc..
Jun 23, 2010 | HP w1907 LCD Monitor
OSD Locked pop menu
You must reset the on screen display in the menu. Hold down the Menu button for at least 60 seconds. A menu list will appear on your monitor screen. Using the adjust button, press the arrows to enter the menu. Scroll down to the Reset section.
On the right side of your screen, you will see an alternating Yes/No choice. When the Yes message flashes, press the Ok button. The menu should be reset and the flashing OSD control message should disappear.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 29, 2010 | Philips 190B6CB/27 19" LCD
Osd lockout
I hope it helps.
All the best.
Mar 29, 2010 | HP w1907 LCD Monitor
This osd lockout pops up quiet often on my screen what can it mean?
Try this
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
Mar 25, 2010 | HP Pavilion dv6000z Notebook
OSD lockout, monitor menu appears and changes input automatically
the menu button might be jammed, try pressing it long and releaseing it, sometimes that happens to me
Feb 14, 2010 | HP vp17 Monitor
Hello how do i get rid of all the viruses in my computer and how do i stop the osd lockout from popping up on my computer
You can install and run a combination of anti virus and anti spyware software
http://www.avg.com/us-en/download-trial
Install and run the same.
Press the menu button on the screen, you would default go to OSD menu, move the OSD lock to off mode
Thanks for using Fixya
Proton
Nov 12, 2009 | HP W2207H 22 Notebook
Osd lockout
If you encounter an OSD Lockout error with your monitor simply try the fixes on this page:
http://www.thefakegeek.com/2009/04/how-to-unlock-an-osd-lockout-problem/
Mar 27, 2009 | HP w1907 LCD Monitor
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
