Instructions on how to operate british gas thermostate control
Electricity went out for a day and now I can't get the mr. slims to work??
Posted on Nov 18, 2010
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
I need an operating manual for a Siebe T45/British Gas PT5 central heating temperature control.
You have this posted in the car and truck problem category. Please re-post.
Jun 11, 2012 | Cars & Trucks
I have a hotpoint freezer FZS175, the alarm is going off. I've followed the instructions, turned the thermostat to zero, waited, then back to mid-way, pressed the fast freezer button. The freezer
Just had exact same issue with our FZS175 upright Hotpoint freezer - could not reset the alarming state.
Tried defrosting (even though it didn't look like it needed it) but still no change.
Then found the shaft of the little plastic thermostat control knob had sheared off. The only way to tell this has happened is to remove the control panel cover (switch off at mains first of course).
Superglued the broken knob shaft back together, inserting a 1mm steel reinforcing pin (cut from a woodworking panel pin) to prevent it happening again, and all is now well.
I think I am in the wrong profession (British wildlife documentaries)!
British Nature Films Wildlife films of the British countryside
Mar 15, 2012 | Refrigerators
How to programme rc2 british gas thermostat
The British Gas RC2 is a re-badged Drayton Digistat and I managed to find installation and operating manuals for that at www.gasapplianceguide.co.uk
Go to the section 'Lost your instructions' and look for Drayton 2F & 3F Digistats (earlier type) for a downloadable copy of the manuals.
Following them got my RC2 up and running though it was a bit fiddly at times.
Hope this helps.
Oct 27, 2011 | Honeywell Programmable Thermostat Heater
I need the operating manual for british gas wireless central heating thermostat control RC2, WR1, UP2.
These are Drayton Digistat controls re-badged. RC2 = Digistat2
WR1 = Digistat SCR
Cannot now find manual for Digistat2, but updated Digistat2+ can be found at http://www.draytoncontrols.co.uk/Digistat2RFProgrammableRoomThermostatWireless.aspx
The Commissioning Guide will show the SCR and now to reset it.
Sep 11, 2010 | Heating & Cooling
As soon as i hook up the thermostate it flashes the 3 flashes code and i have already tryed a new thermostate .... as soon as i unhook the thermostate it flashes for normal operation with no call for heat...
Try using it without the thermostat, tie the two thermostat wires together or put a jumper between
r and w. If furnace operates, you must have wrong style of thermostat
Jan 28, 2010 | Mr. Heater Natural Gas Garage Heater -...
1986 Bronco II, 6 cylinder. Finding gas mixed in oil. Will start, but has problems running. Power isn't what it should be. Main problem is gas in the oil. Where could this be coming from.
from unburt fuel in the motor and exhaust. Completely sure thats it. had same problem. Make sure your engine is running hot and and normal operating tempurature. check over all your thermostate sensors. check to make sure actual thermostate is not stuck open. to much gas going through carburator. spark plug not getting efficent fire.
Jul 23, 2008 | 1989 Ford Bronco II
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
