Question about Dishwashers
No incoming water when running cycles. Aslo, it does not stop
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Aug 29, 2010
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
Washer error on rinse cycle
E11 means the Fill time is too long. There are a whole bunch of tests to perform - but the easiest is to replace the hoses going into the machine - I had the same problem and tested my hoses - they looked fine - but my machine would do this every so often - turns out my hoses had "check valves" that were a safety design to prevent freeflowing incase one burst.....well the valve was going bad. Replaced both hoses - never had a problem again. But anyways... here are the other tests...
1. Is the incoming water flow normal?
Yes. Go to step (4). No. Go to step (2)
2. Are the incoming water faucets turned completely on?
No. Turn water faucets on. Yes. Go to step (3).
3. Is the incoming water pressure above (30) psi.
No. Have customer correct pressure problem.
Yes. Check for kinked or blocked incoming water hoses, clean
the incoming water screens. If problem still remains, replace the
water inlet valve assembly.
4. Does the fill water continue enter the washer?
Yes. Go to step (5). No. Go to step (6)
5. Remove power from the washer. Did the water fill
stop?
Yes. Go to step (6) No. Replace the inlet valve assembly.
6. Good models, check the pressure switch.
Pressure switch checks good. Go to step (8).
Pressure switch checks bad. Replace pressure switch.
7. Better models, replace the pressure sensor.
If this did not correct the problem, go to step 8.
8. Replace the control board.
Good Luck!!!
GOOD LUCK!!!!
Apr 05, 2014 | Frigidaire ATF6000ES Front Load Washer
Intermitten cycle. Stops during cycle and flashes 20/. Motor runs, but no water in and out.\r\nThanks Leah model DX 303 Sk
Check your water flow in the hose pipe. clean the incoming water strainer located on the wash machine body where the water inlet hose is connected.
You can try pouring water up to 10 liters in the wash chamber. Close the door and run .
May 18, 2010 | Dishwashers
Whirlpool frig won't fill the ice maker sounds like running but no watersomeing into it
If you hear the sound of water at the end of the harvest cycle, verify the plastic water line on the back of the refrigerator has not come out of the fill tube or water valve. Aslo verify it is not cracked and leaking. If so, water would be running onto the floor and damage to the floor could result.
Sep 11, 2009 | Refrigerators
Just purchased a used LXIh4 temp on diplay only goes to 155F
The incoming water determines how fast the DW is ready for another cycle. For running continuous cycles, the incoming water will need to be 140 degrees. If you pause 2 minutes between cycles, the temp should remain consistent with a 120 degree supply.
Jun 16, 2009 | Hobart 25 in. LXIH-4 Built-in Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
Kenmore Washing stops at spin cycle.
It sounds like your lidswitch. If it spins after you open and shut the lid, you must be jarring the lidswitch. This is a safety so kids can't open the machine while it is spinning fast. Just replace the lidswitch.
Jan 19, 2009 | Admiral AW22 Top Load Washer
Won't Stop
Water pre-heating
Water pre-heating
Aug 03, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
