Question about Xerox CopyCentre C20 Black and White Copier
My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent through the document input tray. Copier is 3 years old. Any ideas?
  • 52 Answers
The paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
Posted on Aug 27, 2010
Xerox Copier C20
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 09, 2008 | Xerox CopyCentre C20 Black and White...
My c-20 copier will not print from glass. prints blank pages. will only print the ones placed on the feeder.
I know this silly, but you put the originals on the opposite end of the glass. I don't mean to insult anyone, but I don't know your experience with this machine.
The fact that it copies thru the feeder, tells me the copier is ok. The doc feeder uses the same optics.
hope this helps
Feb 07, 2011 | Xerox CopyCentre C20 Black and White...
Which toner I could use for copycenter c20?
Use OEM. Xerox cartridges only if you want reliable clear prints.
I have tried many different generics. I wouldnt recommend using anything but the OEM cartridge. They just perform better.
Oct 23, 2010 | Xerox CopyCentre C20 Black and White...
CopyCentre C20 Black line showing up on the left side of the page
Hello sir; When you make copy is through by ADF? make another copy leave on the glass, compare both, is that same with the line then you have to replace drum blade, if first one with the line and second one without the line, then you need to clean a narrow strip glass on left hand side of the plateform.
Jun 05, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
XEROX CopyCentre C20-Blank stripe going down side
Open the cover and put a piece of paper on only half the glass, and make a copy. BLOCK the left side of the glass with the blank paper.
See where it is blank. Most of the times that is a dirty or haved up mirror in the scan head. One of the small mirrors in the black assembly under the lamp. When a digital copier scanner optics become dirty, the image in that area becomes very light .
Mar 18, 2009 | Xerox CopyCentre C20 Black and White...
Xerox copycentre c20 paper jam in 2 how do i get it out please
Unplug the machine, open the right door. Get a phillips screwdriver.
Look on the upper portion of the paper path, you will see an assembly with yellow waning stickers that say HOT. There are 4 silver screws on that fuser assembly. Remove those screws, and unplug the white connector. Pull back toward yourself to remove the fuser.
Lay it down and remove 2 silver phillips screws , it will open up and you can remove the paper. Make sure the machine has been off for a half an hour or so, It is hot. Take a good look at the black aluminum coated roller on top. See if it looks smooth and clean, If it has a lot of toner built up on it, you will have to repalce the fuser or it will continue to jam and give you ghost ( light reprinted) images up and down your page.
Also the M20 does not handle large black ares on a page such as a picture or magasing cover being copied. Largs solid areas tend to stick to that heat roller. If you do copy a photo, try and allow about 2 inches on the top of white. Just move your original down on the glass about 2 inches from the edge. 2 inches to tie right of the edge of the glass.
Jan 18, 2009 | Xerox CopyCentre C20 Black and White...
XEROX COPYCENTRE C20
u can find manual for this copier at the link below:
www.lostmydrivers.com
Jan 10, 2009 | Xerox CopyCentre C20 Black and White...
Xerox CopyCentre C20 Black and White Copier Logo
87 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
