Question about Konica Minolta bizhub 180 All-In-One Printer
I have the error C0F32 (Minolta - 210) on my display. I have to replace some parts ou just put some code?
    President:
  • Konica Minolta Expert
  • 347 Answers
Yes, you have to replace the parts which are necessary to be replace.If you do not want to replace the parts and also want to get rid of this problem then please perform these steps.....
1-Press utility button. 2-now press these buttons quickly stop, 0, 0 , stop, 0, 1. 3-You are now in service mode.here, scroll down and select ADJUST. 4-Now select ATDC gain. 5-Now increase the value shown on the display for example if the value is 145, increase the value to 165 or 170. To increase the value, press the C button to clear and now enter the new value by pressing the numeric keys on panel. After this press yes button and then press rest button.Re start the machine and start making copies..........
Posted on May 13, 2011
Konica minolta buzz 211 printer error c0f32 ?
Off-on and press the stop bottom :) its trouble reset
Aug 23, 2015 | Konica Minolta Office Equipment & Supplies
How to clear error code c0f32 problems by minolta Di152
replace the developer and drum , clear counter and run F8
Mar 24, 2015 | Konica Minolta Bizhub 180 Di 152 152f...
Help me to reset error codes c0070 & cof32 on minolta bizhub 210
C-0070 is the toner bottle, remove it, power off the machine, then with the bottle out turn the machine on, let it go thought its routine when it ask for toner install it PROPERLY if the knub on the bottle dented damage in anyway replace do not use the damaged bottle. the C0F32 is the toner is not properly mixing in the the developer because it is not getting any toner see above, Might need to replace the developer also.
Jan 27, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
How to clear error code C0F32
by khan
Jan 16, 2011 | Minolta Di3510 Fax
Code error C0F32
Replace the drum and developer, make sure it is done right, clear counters first be for removing the old image unit, replace drum, developer, and cleaning blade, the reinstall run F8 should be good to go
web site below for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 08, 2011 | Minolta DiALTA Di350 Laser Printer
Minolta di20 c0f32 error?
C0F32 Faulty ATDC Sensor E1
The value of data read by E1 is faulty. [E1 reading is 7% or
less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA
PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed
even when an I/C with the same T/
C as that of a new one has been
installed? Change the I/C with a new one
installed and an F8 operation run?
(Be sure to record the ATDC control
voltage setting value if an F8 operation
is to be run.)
YES Change PWB-A, install the old I/C,
and return the ATDC control voltage
setting to the value recorded. If
“C0F32” or “C0F33” redisplayed,
change the I/C with a new one.
is to be run.)
NO Change the I/C with a new one.
Jan 25, 2010 | Minolta Office Equipment & Supplies
C0F32 error displayed in new machine just in 25000 copies
Is the copier is brand new out of the box? If so you have to call a dealer or a good friend that works on them to help you by pass the set-up error code. They put that little curve in to stop none dealer from installing there copiers.. Good Luck......
Jul 29, 2009 | Konica Minolta DiALTA Di200 Copier
Konica Minolta bizhub 180 All-In-One Printer Logo
2,781 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
