Question about Garden
Power washer motor will not kick in. I've got a Husky 1750 power washer; probably 4 years old but used only once or twice. I've got the unit completely set up, I've checked the GFCI, water supply, etc. When I switch it on, I can hear the motor's electric hum for a few seconds and then it shuts off. The actual pressure motor never kicks on and therefore I get no pressure. The water will flow through at garden hose pressure, but I'm not getting any compression.
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. When an electric pressure washer sits for an extended time the residual water inside the pump eventually starts the corrosion process. In as little as 2 or three months enough corrosion can form inside the pump to freeze the pistons in the pump and of course the motor in place. Here is what you can attempt to try and free the pistons. Place the unit on a piece of cardboard and then slowly introduce a light weight oil into the water supply connection. You will need to ensure you add enough oil that you start to notice it at the pressure hose connection. Let this sit overnight on the cardboard.
Next day you need to attempt several rapid off and on sequences (10 at a time less than 1 second each) using the torque of the motor to momentarily make micro movements of the pistons. Let the unit sit for 30 mins if it did not clear and try it again (10 more times rapid on/off cycles) Let it sit another 30 minutes and make the final attempt to get the pump free.
It most likely will free up by doing this but if the interal corrosion / debris is too much your faced with having to physically remove the corrosion by opening the unit and doing repair.
Kelly
Posted on Aug 26, 2010
Husky deckmate
Looks like it might be a faulty/sticking pressure sensor/switch on the pressure side of the unit.
Mar 10, 2014 | Garden
Anybody know how to remove the wheels on a Husky 1750 power washer?
where does the link-mechanical gov. rod connect to the carburetor on the craftsman pressure washer number 919.762350.
Sep 28, 2013 | Dayton Wire Wheels Dayton Twin-Piston...
1750 husky power washer
Buy a washer kit for it at Home Depot.
Apr 28, 2013 | Cars & Trucks
What does the code f17 mean? I've had it happen twice according to the mannual I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore...
F7
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Generally if everything checks good, you'll want to replace the MCU because it's not reading the motor correctly.####
May 11, 2010 | Kenmore Elite 45986 Front Load Washer
What does the code f17 mean? I've had it happen twice, according to the mannual, I cancel the wash cycle and select drain and spin. Why does this happen? I have a less than a year old front loader Kenmore...
F7
Mar 19, 2010 | Kenmore Elite 45986 Front Load Washer
Hi I need a Wiring Diagram for husky power washer 1750. I took the power switch out and I can't remember how the wires go back on. Thanks!
I did some searching I found www.huskypowerwasher.com/manuals_specs.php.
Go there and look for your model.
Good Day.
Nov 06, 2009 | Garden
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
No soap dispensing in power washer
ball and spring stuck on end in in filter
Mar 29, 2009 | Garden
Electric Pressure Washer
try running the machine without the hose attached if the machine runs ok then it is probable the there is a blockage in the nozzle if the the machine still cuts out then the pressure switch will probably be stuck or faulty this switch will be inline with the on/off switch and the motor it can be checked using a multi meter after dissconecting the power.
Oct 14, 2007 | Karcher 2500 PSI Pressure Washer
Garden Logo
403 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
