Question about HP Pavilion dv9000z Notebook
Hp compaq 6715b...dos not turn on, with battery installed or removed, even though it is plugged in, checked voltage coming out of a/c adapter, it has 19vdc, power indicator on laptop does not illuminate when plugged in, nothing happens with battery removed and i press power button, with battery installed and i press button orange indicator flashes, indicating it has a dead battery
  • blriv Aug 26, 2010
    so if i try a new power adapter and it still does not work, do you think i should replace the motherboard???
    so if i try a new power adapter and it still does not work should i try a new motherboard????
  • HP Master
  • 6,993 Answers
Test the adapter with another laptop in other to confirm if truly the adapter is still good. If the adapter works, then it means your laptop is having a power problem.
This has nothing to do with the battery because whether or not the battery is good or bad, that doesn't say the laptop shouldn't work with the adapter.
So the problem as to be either from the laptop's power board or from the AC adapter.
Tale care.
Posted on Aug 26, 2010
  • Walesarumi
    Walesarumi Aug 26, 2010
    if your try a new adapter and it doesn't work, then it means you will have to replace the motherboard.
    Take care.
Hp compaq 6715b charging problem
Good day .If i was in the your position i would carry the laptop to a repair shop and let them check it and maybe change the charging port of the laptop
Jan 14, 2014 | HP Compaq 6715b Notebook
Hi i was using m compaq nc8000, when it turned off suddenl even though it was plugged into the ac...now when i tr to turn it on it sounds like it is going to start,the yellow charge light comes on and then...
Hi
try removing you battery and powering it up....
it could be your charger,even if the power led is on there still could be a voltage failure...i,ve sorted a few laptops like that before.....
Or it could be the charging port connected to the motherboard??
Try to gently wiggle the adapter going into the charging port and powering it on...to see if that makes a diffence....
Hope this helps...if so please take the time to rate it,as i,ve taken the time to answer you...if i can be anymore help...
Regards
Apr 02, 2011 | HP Compaq nc8000 Notebook
Just installed WIn 7 onto mt Compaq 6715b and now my wireless networking doesn't work
You need to configure it again.Win 7 has a different set up configuration.
Oct 25, 2010 | HP 6715B Wireless Adapter
Hp compaq stopped working after adapter cord was damaged. replaced adapter. press power button, won't turn on. How do you check battery?
Your laptop should start even without battery inserted.
You should check the ac adapter (try to measure the output voltage )
Mar 09, 2010 | HP Compaq nx6310 Notebook
Flat battery
Normally the micro switch that decides to charge battery or use main power goes, its a known fault in laptops today , its a big job to replace them . your best bet is to search ebay for a secound hand board or even the same laptop for parts and replace your main board. hope this helps you in some way.
oh when you plug in the main adapter hold it in a angle slightly for 5 secounds and see if it reconizes its plugged in try figure if its a conection problem on the laptop itself. but i think myself its the micro switch on the main board that is fualty.
Nov 30, 2009 | HP Compaq 6715b Notebook
Wireless connection 6715b Compaq
Go into the setup/BIOS and disable the wan/lan switching feature.
Oct 30, 2009 | HP 6715B Wireless Adapter
Voltage HP 6715b
Look up the voltage acceptable for a HP  6715b laptop in the manual  that came with it. Go to Radio Shack and buy a $9.00 Grounded Adapter Plug. Be sure you take the HP power cord.
Feb 07, 2009 | HP Compaq 6715b Notebook
What voltage will a HP 6715b accept?
hi no need of transformers.. ur lappy is ready to accept 230v-240v...
Feb 07, 2009 | HP Compaq 6715b Notebook PC
HP Pavilion dv9000z Notebook Logo
519 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
