Question about Compaq CV 7500 17" CRT Monitor
The contrast bar comes up on my monitor allday long. I can not get it to go permentaly. It just pops up when it wants to. How can I remove it, and use it only when I need to??
Contrast button stuck? driver issue? etc?
It is a hardware problem and needs a replacement. Also try to unpress/release it by tapping lightly on the monitor. If you feel it is a driver problem then go to Start->Control Panel->System->Hardware->Device Manager->Monitor. Remove this monitor and from Action in the Menu select San for New HW. the monitor drivers will be loaded and you can then reboot.
Nov 08, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
My monitor pops up the contrast menu without doing anything.
Actually the button for setting the contrast is a bit loose thats why whenever their is a **** os little movement in the moniter opf ur PC then the contrast button get pressed automatically and the pop up comes up
Sep 07, 2009 | ViewSonic VA721 17" LCD Monitor
Dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Jun 11, 2009 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Dec 07, 2008 | Acer AL1912 19" LCD Monitor
Monitor spazzing out with the contrast
See what happens using a live cd or usb.
Aug 19, 2017 | ViewSonic VA702b 17" LCD Monitor
Brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
Dec 15, 2007 | Dell E173FP 17" LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Compaq CV 7500 17" CRT Monitor Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
