Question about Ryobi Garden
Ryobi gas trimmer loses power after about 10 minutes
Toro trimmer is losing power gas is spraying out of the carebutor
Posted on Apr 07, 2013
4 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: ryobi trimmer model ry34420,starts,but stops when
Hi waynedavis50...
Yes a 10% Ethanol fuel can have some adverse effects on certain carburetor parts.
It can cause your "0" rings to grow and close off vital fuel passages and also cause them to start disolving and can plug passages.
You may need to rebuild your carburetor, try what I suggest below.
Check your fuel filter if you have one, normally they are located in the fuel tank.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on May 12, 2011
Testimonial: "thanks,this is a newly rebuilt engine,what do they do when they rebuild?"
AlmostBob
  • 550 Answers
SOURCE: Gas/oil mix ratio for Ryobi Trimmer
50:1
Posted on Oct 10, 2008
wilsodfarm
  • 986 Answers
SOURCE: Need to know gas oil ratio for Ryobi SS30 gas string trimmer.
50 to 1
Posted on Sep 14, 2009
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
My ryobi whipper snipper loses power when I turn it on its side.
If its gas powered, it relies on gravity flow to let fuel flow into the carburetor. When you turn it on its side, less fuel is flowing through the fuel line, meaning its not designed to be used as a side edge trimmer.
Nov 29, 2013 | Garden
Carburetor is spraying out gas and trimmer is losing power
You have a clogged Needle, Clean the Carburator and it will be ok
Apr 07, 2013 | Ryobi Garden
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 105r overheating
Well, I don't know just yet.
Is the smoke blue and does it do it the whole time that it is running? If so, the gas could be mixed too rich.
Exactly how long does it run? If it is 10-15 minutes then it is probably your gas cap that is the problem. It is clogged with dirt. The gas cap must be able to breathe or the carburetor won't get the proper gas flow.
Jim
Jun 09, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 790r trimmer has low power and stalls
Maybe a quick fix and maybe not
check your muffler the factory puts a spark arrestor screen that tends to plug after awhile
there is a little plate on the side muffler that needs to be removed to access the screen you may need a torx bit or allen wrench to remove
you may have to remove the back half of the plastic cover to access the screws
remove screen and clean with carb. cleaner or equivalent make sure you can see through it and reverse the procedure to put it back
Jun 07, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
194 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
