Question about Canon Cameras
I have sx100 camera. when i am using to take a picture with flash i cannot take the next picture immediately. some times it take more than 30 sec. without flash no prob. this is not a memory card problem.
  • 734 Answers
It depends on your battery condition, flash capacitor will charge faster if battery is freshly recharged. Or battery has larger current capacity. You can shoot pictures with flash faster if its fill-in or closer in distance. Which means capacitor recharge is not totally depleted for each flash duration.
Posted on Aug 26, 2010
Can you explain what 10 second video clips at 30 frames per second mean?
It means that the video will last 10 seconds. 30 frames/sec is the quality of the video. It is the number of individual pictures take per second. Example: 10 frames/sec produces a jerky video but is sometimes used for security monitoring. On some cameras you can reduce the frames/sec to get a longer running time.
May 25, 2015 | Cameras
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
What setting is best for taking pictures at night(?)
IR/ night vision, Black and white also seem to work good most of the time too. Just keep playing around until you find one that suites your needs. Happy refraction !!!!.
Apr 03, 2015 | Vivitar ViviCam 5385 Digital Camera
Time lapse
If your camera does not have a time lapse setting then you need to do this manually or make a device to trigger the remote control on your camera at predetermined intervals.
May 19, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
I dropped my Canon PowerShot SX100 Camera. It takes photos just fine, but I can no longer download to a computer. When I turn on the camera for downloading, a "communication error" message...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 19, 2010 | Canon PowerShot SX100 IS Digital Camera
Really Grainy low quality pictures with my new camera.
Try shooting with ISO value of 200 or less; or set to "Auto".
If you're missing the manual, you can get it in English, here. Page 76 briefly discusses ISO settings. This camera can select an ISO as high as 1600. ISO has to do with graininess of film - the higher the number - the more grainy the images. Higher ISOs are selected when light levels are low and no flash is used or is usable (such as when the subject is too distant). Some photographers use higher ISO settings with high shutter speeds to stop fast moving objects (like wheels on a race car). The grainier the film, the quicker it captures light. Fime grained film takes longer to capture light.
Generally, pictures taken outdoors in sunshine look best when ISO is 100 or less. 100 is a good choice for well lit indoor pictures, too; but may be better with an ISO of 200. ISO works like this:
If a picture can be properly exposed with an ISO of 100 in 1/15 sec, it would require only 1/30 sec at ISO 200, or 1/60 sec at ISO 400. When you double the ISO value, the exposure times are halved. What's the big deal about 1/15sec, 1/30 or 1/60 sec you might ask? Easy! the picture will probably be blurry at 1/15 and even 1/30 sec exposure time, due to the camera recording even the slightest movement of your hands. You'll need to supply a tripod or do something else (such as increase the size of the opening of the aperture or f-stop) to get a properly exposed image.
I hope this helped - if it isn't an ISO problem - let me know. Good luck!
Dec 10, 2010 | Canon PowerShot SX30 IS Digital Camera
Model no. PowerShot SX100 IS my date &time stamp problem
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jan 04, 2010 | Canon PowerShot SX100 IS Digital Camera
There is a flashing number inside the screen that I cannot remove, and my pictures are not coming out as they used to.,.they are very dark,,.how do I remove this flashing number it says 91:01
Just follow the steps below to remove the error message.
Turn off camera.
Remove the battery or the power supply.
Turn the switch to CAMERA for about 30 sec.
Turn the switch to OFF.
Install the battery or power supply.
Turn the switch to MEMORY.
Open the LCD cover and press the RESET button .
You will be prompt to adjust date/time. Do take some pictures.
Hope this helps.
Thanks for using Fixya.
Do rate the solution.
Dec 14, 2009 | Sony Cybershot S650 Digital Camera
Can't get the camera to Flash
EXACT same problem. Tonight I tried to take a picture and heard a loud pop sound but I didn't think it was my camera... anyway it took the picture but didn't use the flash. Later, my sister went to take a picture with the flash and it made the same loud pop noise and now the camera wont work if the flash is on.
Jan 19, 2008 | Samsung Digimax S630 Digital Camera
Cameras Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
