Bright white screen, no video, no osd, sound normal.
  • 70 Answers
It sounds like you have a defective screen panel.
Posted on Aug 26, 2010
  • laschott_000 Aug 26, 2010
    Sounds like it to me, but I will never know. Don't want to replace screen to find out. Not cost effective repair.
  • J Lopez Aug 26, 2010
    Yes, dont replace the screen because it would cost more than buying a brand new tv. I have replaced them before for clients but always ends up costing more than what tv is worth. This is a typical issue with some Vizio and Toshiba.
Why is there a white vertical bar down the middle of the screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 28, 2015 | Televison & Video
White Screen with audio. No video at all. No OSD from Menu button. Possible cause?
if sounds is working the it must the screen is under repair,change it
Jun 13, 2011 | Cell Phones
Normally, when the monitor is switched on, a blue screen is shown momentarily, with 'acer' right in the middle, before it shows the image that the computer is sending. But now, the screen does not show...
It sounds like either a bad signal input , possibly from a loose plug on the cable from the PC or bent pins on the plug / the video graphics card in the PC/ or the settings on the monitor need adjustment. Use the OSD (On Screen Display)
First check to make sure both ends of the cable from the PC to the monitor are not damaged and are seated good & tight.
If those are fine then unplug both cables from the monitor & leave unplugged for 10 minutes or so to see if the screen has an automatic reset.
If that does not work then use the monitors OSD (On Screen Display) to adjust to default settings. If that does not work, plug the monitor into another known good PC.This will tell you right then if its the monitor or "Your" PC.
__________________________________________________________
Here is your manual if needed
http://www.retrevo.com/support/Acer-AL1717-Monitors-manual/id/719ag107/t/2/
Oct 09, 2010 | Acer AL1717 17" LCD Monitor
My dell S1709W flat panel monitor turned white
http://support.dell.com/support/edocs/monitors/S1709W/en/ug/operate.htm#Using the Front Panel
NOTE: You can also lock or unlock the OSD by pushing and holding themenu-logo2.gifbutton for 15 seconds. (Top of the buttons on right side)
Apr 07, 2010 | Dell Computers & Internet
Colours are getting out of sync, picture distortion
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 29, 2009 | Mitsubishi WS-55908 55" Rear Projection...
Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Dec 25, 2008 | Panasonic CT-36HL43 36" TV
OSD screen lock
The OSD is controlled by the video card board (logic board)
It is information stored on the eprom, not something you can just get to. It has to be programmed.
To gain access to the OSD Service Menu from a user service point you normally access it via a series of buttons on the control panel. Holding several buttons at once in a set combination that is particular to that brand, or even that individual series of monitor.
OSD just means "On Screen Display" the menu system and the service menu are the OSD.
Apr 21, 2008 | Computers & Internet
Horizontal Bright White Line in Middle of Screen.... and thats it.
by the sounds of it the mon is in a word goosed
but please dont open it up to try and tinker with it !
as they hold a charge for a while beware !
Nov 10, 2007 | Compaq FS 7550 17" CRT Monitor
On bright screens picture goes to white and shakes
Sounds like a bad crt, also has you set been used to play video games if so this could be a cause for bad crt, weaking tubes
Oct 23, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
