Question about Bryant 463AAC008BA Air Conditioner
I HAVE NOISE AS DESCRIBED ABOVE ,I HAVE A GE ONE SPEED ,208VOLT THREE WIRE LEAD ,I BELIEVE I HAVE A FAN PROBLEM ,I HAVE A SPARE FAN FROM ANOTHER AC I REPLACED ,I NEED TO REVERSE ROTATION ON PRESENT MOTOR IN ORDER TO USE FAN ITS THE OTHER ROTATION .WILL REVERSING THE BLACK AND RED LINE LEADS DO THE JOB ,LEAVING THE BLUE TO THE CAPACITOR ,SURE WOULD THANK YOU FOR AN EMAIL ANSWER ,KIERAN NESBITT KIERAN_616@HOTMAIL.COM.
  • 455 Answers
Hello YES red & black will change the direction,leave the blue as is.
Posted on Aug 27, 2010
Testimonial: "talked to grainger rep ,on 1 speed he didn;t think switching leads would solve problem ,i ordered a new motor,thanks for your input ."
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
GE D52GW12 HDTV CHASSIS ITC222
The model indicated does NOT use a chip for convergence output; the convergence circuit is divided across three circuit boards.
Does the convergence option appear in the menu or NOT?
Dec 06, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a new fan motor for a ge for a ac unit for outside home and the old is a 4 wire and new is a 3 wire has black,yellow,brown the old 1 has black,brown,red,blue or purple wire how do i rewire thie...
this soounnds as though it for a 2 spped fan motor look at the old motor and see the RPM and then look at the new motor plate it shuld show ou which wire is for the speed required. Hope this helps ..Jon
Jul 25, 2011 | Heating & Cooling
I REPLACE SWITCH 77075 now IT HAS ONE SPEED IDID ONE WIRE AT TIME WHAT IS THE PROBLEM
I don't know your specific fan or switch.
Following link is TYPICAL illustration of 3-wire fan switch wiring:
http://waterheatertimer.org/images/Fan-motor-1-500.jpg
Three way switch is designed to match TYPICAL fan motor windings.
Motor windings are insulated copper wire wrapped around metal fan housing, similar to electromagnet you can make by wrapping wire around a nail.
Inside the fan motor are two windings.
Winding 1 for low speed.
Winding 2 for medium speed.
And when both windings are combined, that makes high speed.
You have to test your switch.
Usually the hot lead connects to red. So the red connects to each of the other wires.
Then pull the chain and use continuity tester between red wire and other wires to see how the switch is set up.
Jun 27, 2011 | Westinghouse Electric Westinghouse...
I have a 3 speed fan with a red, blue, black an white wires, how are the supposed to be wired with power. the wires go to a little black box that appears to just be wires with no circuit board
The BOX is a GE splicer - with 6 wires - 2 grey power wires, then the red, blue, black, and white from the fan motor. I have the same problem and cannot find another GE SPLICER 3 SPEED SWITCH for the fan. All switches that I have tried have 4 connections.........so a WIRING DIAGRAM would be GREAT!
Can anyone offer any help? I have tried every electrical store in the area!
Thanks
May 29, 2011 | Patton U2-1887HO Floor / Box Fan
Subject: 2004 isuzu rodeo...my ac/heater blower is not working
The resistors are in circuit only on the lower fan speed settings.
On the highest speed setting, power is switched directly to the fan motor.
Check fan power supply fuses,
Check power is available to the fan when high speed selected.
If all above OK, apply power directly to the motor to verify fan motor runs- if it doesn't the motor may need replacement/repair.
Jul 29, 2009 | 2004 Isuzu Rodeo
My GE profile refrigerator makes a fan noise
Hello my name is Tim Ehrhart, it sounds like you may have a wire that is hitting the fan blade wich can be seriouse as if it shorts out it could catch fire. A trick to fix this is to take off the cover and make sure the fan is clear or all wires and everything else, if there are wires either tape them back, hot glue them or redirect them away from the fan. I hope this helps you out.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Mar 08, 2009 | Dometic Rooftop RV Air Conditioner
Air and fan control
you have a reostat that is located in the blower motor housing it will have a 2 wire lead to it it's helld in place by 2 screws this is what regulates the fan speed. this should be replaced ..please rate the solution...thanks
Sep 08, 2008 | 1999 Chevrolet Silverado 1500
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Heating & Cooling Logo
60 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
