Question about Sharp AL 1631 Copier
RED LIGHT FLASHING AND COPIER WILL NOT MAKE COPIES
  • 61 Answers
There are a few lights, If it looks like 3 dots in a triangle toner empty, if its one that looks like a cylinder drum needs replaced. and one that looks like a 8 lighting bolt paper jam. If you have removed all the paper and still getting the warnig check the flap on the fuser is moving smooth, open right side door and check the hot rollers above the drum. One place to look for hiden paper is just before it comes out of the machine you might get 2 inches that comes out and cant see it.
Posted on Aug 26, 2010
Red light flashing
could be low on paper or minor problem Self Help Product Support Konica Minolta Business Solutions Inc try this
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 22, 2015 | Konica Minolta Bizhub C360...
Blue center light flashing, won't copy from any computer
So Sandra, it will make copies but does not print from any computer. Have you installed print drivers on the network? Can you ping the copier?, any resent changes to the network? Check the network connection at the copier, green light flashing/orange lights flashing? Can you print a doc. or a pdf., or email or web page try different programs? Check the network setting at the copier, go to admin setting default pw 12345678.
May 12, 2015 | Konica Minolta bizhub C250 All-In-One...
We are trying to make copies and there was a light flashing and it said 1L and we are unable to make copies the copier has been reset and the toner and drum have been replaced already and i have also...
I have a tip posted here at Fixya that covers the Sharp AL Series Copier L1 code.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If it helps you with your L1 code then please return here and provide some feedback.
Thanks,
WheatlandServices
Dec 16, 2010 | Sharp AL 1631 Copier
Sharp al 1631 not working properly
That is the drum replacement light reset it by pressing these keys: Clear, then the far left key, then Clear again then far left again.
So C, far left, C, far left
If done quickly like within 4 secomds the display should go blank. If so then key in 24 as if you were making 24 copies.
Now press the print button.
Now key in 7 and hit print again.
You should now be getting flashing zero's
Turn the machine off then on and the light should be gone and the copier is ready to use.
You can reset your drum life at least once with no problems.
Jan 05, 2010 | Sharp AL 1631 Copier
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
When i turn on the copier it is stuck on 10 copies and a light flashes to the left of the copy number. I don't have a manual. I don't know what the flashing light means.
If the light is a red light with a flash shape then the machine probably has a jam. Look for jams and once you have cleared any jams switch the machine off and then on again. It could be the toner light if there are about six red dots - in this case you need to add toner.
Jun 30, 2009 | Canon NP 7130 Black and White Copier
Aficio 200 copier
replace the laser scanner motor..approximately $144.00 dealer cost retails for $ 210.00 takes 10 mins to put in.
Oct 14, 2008 | Ricoh Aficio 180 Laser Printer
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
114 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
